I've built the below circuit as part of an audio DAC output.
In simulation it operates as expected, generating a clean output from the differential input. However in the actual built circuit, something goes wrong and it seems unable to swing below -1V. I've quintuple checked that the -12V supply is working as expected, and removed R21/22 and verified the DAC output is clean to that point. I thought perhaps the DAC outputs were getting pulled away from their DC bias and getting clamped there, but they seem fine and well above ground. The opamp is also behaving as expected here, both inputs are at identical potential and match the output. Note that R28 is not in circuit, so the mute circuit isn't in play. Not sure what I am missing here, probably something dumb that I will see a few minutes after posting here, but I'd appreciate some help!
Edit: Okay so inline attachments don't work...
