Author Topic: Why do I need this resistor  (Read 1996 times)
Offline tiltitTopic starter
« on: July 24, 2014, 08:44:29 pm »
Hi everyone,
I am currently playing around with nixie tubes and using this transistor configuration to turn on the anodes.
What I do not understand is why do I need R4. The base of U$2 should be pulled low by U$1 regardless of it's presents.  :-//
Thanks
Offline neildarlow
Re: Why do I need this resistor
« Reply #1 on: July 24, 2014, 08:56:29 pm »
R4 applies negative feedback to limit U$1 collector current. R3 will only have U$2 Vbe across it and without R4 the current flow through the two transistors would be excessive and with U$1's relatively high Vce lead to excessive power dissipation.
« Reply #2 on: July 24, 2014, 09:12:45 pm »
Thanks.
So if I understand correctly without R4 I am basically shorting out the emitter of U$2 through it's base? I have tested this circuit many times and it definitely does not work at all without R4.
Offline neildarlow
« Reply #3 on: July 24, 2014, 09:22:30 pm »
Without R4 in place U$1 saturates when driven and its Vice will be near ground. U$1 collector current will only be limited by its hFE and limiting in the high voltage supply. U$2 will act as an emitters follower and pull the high voltage supply down. This is potentially destructive and R4 is a required component for correct operation of this circuit.
