Author Topic: This power supply is dangerous right ?  (Read 2093 times)
Offline eevfan007Topic starter
« on: December 01, 2014, 07:39:09 pm »
I pulled this power supply (220V AC) from a cheap shaver i bought. I suspected that is was quite poorly made, had that cheap plastic feel to it.
I don't see any isolation slots, and it seems quite dangerous for a shaver. This is after all something you have close to your face. Notice the N and L markings. The wire was incredibly thin
It runs a small motor at a couple of volts DC it seems, and also charges a 500mAh 1,2V Ni-MH battary too.
Would you trust this ?
Online Zero999
  • 0999
Re: This power supply is dangerous right ?
« Reply #1 on: December 01, 2014, 10:50:07 pm »
It's quite possible perfectly safe, as long as all of the electrical connections, including those to the motor and batteries are well insulated.
Offline Paul Price
« Reply #2 on: December 01, 2014, 11:17:17 pm »
It seems you have not been killed using it so I don't think you were really facing a close shave with death.
Offline hamdi.tn
  • Country: tn
« Reply #3 on: December 02, 2014, 10:52:52 am »
i saw worst, a shaver with only a diode a capacitor and a resistor , and the DC motor obviously, nothing more.  but it shouldn't be dangerous since all metallic part of the shaver are isolated form the circuit.
