Author Topic: connecting traces on opposite sides of a double sided board  (Read 14448 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: December 09, 2010, 08:01:27 pm »
So supposing I did manage to produce a double sided board, how do I connect the traces on the two sides, literally run a wire through the board and solder both ends ?
Offline cfrolander
Re: connecting traces on opposite sides of a double sided board
« Reply #1 on: December 09, 2010, 08:33:31 pm »
Connect the traces with a through hole via! http://en.wikipedia.org/wiki/Via_(electronics)
  • Global Moderator
« Reply #2 on: December 09, 2010, 08:38:39 pm »
right so how do I produce a via at home ?
Offline djsb
« Reply #3 on: December 09, 2010, 08:39:42 pm »
That's what I do. Also you can use the component lead itself as a via, it just takes a bit of practice. That's all you can do unless you are able to make plated through holes.
Hertfordshire,UK
University Electronics Technician, London PIC,CCS C,Arduino,Kicad, Altium Designer,LPKF S103,S62 Operator, Electronics instructor. Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime. Credited Kicad French to English translator.
  • Global Moderator
« Reply #4 on: December 09, 2010, 08:42:24 pm »
right so there is no semi mechanised method for small productions just plain old soldering
Offline djsb
« Reply #5 on: December 09, 2010, 08:53:46 pm »
LPKF do kits.
http://www.lpkf.com/products/rapid-pcb-prototyping/through-hole-plating/manual/index.htm
Not tried this yet, but may be a practical solution.
Hertfordshire,UK
Offline Bored@Work
Offline TheDirty
« Reply #7 on: December 09, 2010, 09:24:31 pm »
Never tried it, but you can try this:
http://www.colinmackenzie.net/electronics/14-pcb/25-thru-hole-plating-diy-printed-circuit-boards
The method that I use, which is kinda semi-production line requires a hot air station.  The steps are.
Drill the via holes and place the board on a piece of wood.
With a bare piece a wire and wire cutters I step through each via.  Put the bare wire in the hole and cut the wire flush.  Step through all the holes.
At this point there should be a tiny bit of loose wire in each hole.
Place a bit of solder paste on top of each via then hit it with the hot air station.
Flip the board and put it in clips/clamps/whatever gets it in the air.  Put solder paste other side and hit it with hot air.
It can be pretty quick.
Mark Higgins
Offline tyblu
    • blog.tyblu.ca
« Reply #8 on: December 09, 2010, 09:26:29 pm »
can use tiny rivets (1mm), but I usually just solder a short wire.
Tyler Lucas, electronics hobbyist
Online Zero999
  • 0999
« Reply #9 on: December 09, 2010, 09:28:50 pm »
I've never made a double sided board before but I'd go for soldering pieces of wire.
Offline johnmx
  • Country: pt
« Last Edit: December 09, 2010, 09:49:25 pm by johnmx »
Best regards,
johnmx
Alex
  • Guest
« Reply #11 on: December 09, 2010, 10:01:08 pm »
Hi Simon,
If you have got to a point where you start using two or more layers and vias, then you should consider outsourcing the PCB manufacturing.
iTead Studio has a PCB prototyping service (I assume outsourced). They can do 10-off generic, 5x5 cm, 2 layer boards for $12. They are based in China, so you should also check postage costs. I cannot comment on their manufacturing quality yet.
Here is a link to their PCB service: http://iteadstudio.com/store/index.php?main_page=index&cPath=19_20
I checked the price of via kits two years ago they were too expensive for what they do. Therefore I would also recommend using small pieces of wire, or component leads where applicable. Just remember not to place the vias under flat packages (e.g. TQFP, SOIC).
To use johnmx's pins you will also need this instertion tool: http://pt.farnell.com/harwin/z1002-00/insertion-tool-track-pin/dp/145248?Ntt=z1002-00
Some sizes and shapes of via rivets can be applied using a mechanical pencil instead of the expensive tool that comes with the kit.
Hope this helps.
Alex
Offline Time
« Reply #12 on: December 09, 2010, 10:11:11 pm »
i always just use pieces of clipped leads from resistors or capacitors etc.
-Time
Offline johnmx
  • Country: pt
« Reply #13 on: December 09, 2010, 11:43:12 pm »
Actually you can insert them without that tool and it’s very easy. I have these pins. For me, the main disadvantage is the size (big in diameter).
It gives more work but it’s possible and I usually do it for my first prototype boards. After soldering the via (made by wrapping wire) I polish it carefully with a sandpaper to reduce the height.
Best regards,
johnmx
Offline Balaur
« Reply #14 on: December 10, 2010, 12:07:49 am »
Hello,
Do you know this method:
http://www.youritronics.com/double-layer-pcb-home-made-vias/
Quick and easy.
Cheers
Alex
  • Guest
« Reply #15 on: December 10, 2010, 12:53:54 am »
Hi Balaur,
Thanks for the link, that's the method a few have proposed.
Johnmx,
I would feel that I am buying overpriced pre-cut pieces of wire.
The standoff of SOIC packages can be as low as 0.1mm and for  TQFP 0.05mm. I imagine it will be of the same order for large SMT chip components too. It is not possible to maintain a reliable electical connection between the tracks on the two layers if you sand off the solder joint to this length; it will crack before that by sanding alone. Therefore it is better to place the via next to the low-standoff component rather than under it.
Alex
  • Global Moderator
« Reply #16 on: December 10, 2010, 06:53:28 am »
that sounds like the best thing at least for prototyping, as someone else said if I were to make loads of the same thing outsourcing would be best
Offline GeoffS
« Reply #17 on: December 10, 2010, 07:40:32 am »
I got a bit sidetracked reading this thread and went looking for DIY solutions to through hole plating.  What can I say? I'm bored.
Thinktink.com has a conductive paste/electroplating solution that looks doable at home but the basic materials are not cheap.
LPKF have the answer if one off turnaround time is more important than money!  The paste/bake solution looks neat, check out the video. I'll have one of the CNC mills  8)
At the sort of prices charged by the above, it would be cheaper just to get 10 boards run off at somewhere like itead or seeed and throw away the ones you don't need.   :D
« Last Edit: December 14, 2010, 02:38:35 am by GeoffS »
  • Global Moderator
« Reply #18 on: December 10, 2010, 07:54:35 am »
ok next dumb question  ;D
now I'm going ever more surface mount and considering double sided (I'm going to start by glueing two boards together  ::))
What is the largest/easiest SMD size to work with for my passives (resistor / capacitors) ?
Offline joelby
« Reply #19 on: December 10, 2010, 08:05:35 am »
0805 are cheap, ubiquitous and relatively easy to deal with. You can buy grab-bags of thousands of 0805 resistors and capacitors on eBay for a few dollars.
0603 isn't too bad either, though you'll probably want a good magnifying glass or stereo microscope and lighting, at least to check your work.
0402 is getting a bit silly but are not too difficult. It can occasionally be good to use a couple if you don't have trouble with larger sizes and need to decouple power pins very close to larger chips and have limited space.
Offline Psi
« Reply #20 on: December 10, 2010, 09:02:10 am »
For connecting top layer tracks to the bottom layer with home made boards i add dedicated holes for that purpose and solder a wire in.
You can sometimes get away with using the holes for top/bottom joins AND components, ie, if you had a resistor laying flat on the pcb you can solder both sides easy and the resistor leg itself joins your tracks.
However you have to carefully watch what you're doing if you go down that road, lots of components cover up the holes, relays etc. so you can't solder both sides. You dont want to find that out after youve made the pcb.
So yeah, i just have dedicated holes for joining the top/bottom. It gets around the whole issue of keeping track of which holes can and cant be soldered on both sides.
But i do agree with what other people have said, making two layers boards at home is pushing it.
It's so much nicer to have them made professionally.
Ya really dont understand how nice it is until you actually have some pcbs made professionally.
The day they arrive and you have your board design in your hands with mask and silkscreen is a pretty nice feeling. And wow is it nice to assemble them when the holes are correctly aligned and you have a solder mask :)
« Last Edit: December 10, 2010, 09:08:40 am by Psi »
  • Global Moderator
« Reply #21 on: December 10, 2010, 10:12:35 am »
oh I do, but for as long as it is a prototype, homemade is  cheapest
Offline TheDirty
« Reply #22 on: December 10, 2010, 01:43:44 pm »
All my resistors are 0805.  They are small enough and you can still pass a trace through one on a homemade board if it's needed.  Then I can just drop resistors into my schematic and they are all 0805 and I don't need to worry about thinking about package size.  I only get a different size if it's really needed.
Capacitors are tough to standardize on, because obviously they change in size based on value.  I try to keep 0603 for 1uf and smaller for decoupling caps.  It's good to have small decoupling caps because putting the caps close to pins can be tough to squeeze things in.  I use metal canister caps now but without reflowing they are tough to solder with an iron.
Mark Higgins
Offline GeoffS
« Reply #23 on: December 11, 2010, 03:59:03 am »
Still on the subject of plated through holes for home made PCBs.
I came across this video on Youtube [www.youtube.com/watch?v=koT4tUit6aU&feature=related]
about a simple process for doing through hole plating. Problem is that it's in Chinese.
Received an answer back from the local distributor as follows:
The process is being used by trial customers in China at this time.
Kinsten are not ready to release it to a wider market yet. I requested
a release date from the factory, but I have not been given one.
The development is on hold until next year due to work on the drilling machine.
As soon as the process is released for full sale I will be supplying it.
No detail son the process though, at least not in English.
« Last Edit: December 11, 2010, 04:15:57 am by GeoffS »
Offline tyblu
    • blog.tyblu.ca
« Reply #24 on: December 11, 2010, 04:31:02 am »
Very interesting -- that's many more steps than I've seen typical DIY kits use, and the results look good, though it looks like you have to drill twice (once beforehand, once with the cured paste).
