Author Topic: Connection of NC pins in the MCP1703 LDO regulator  (Read 1338 times)
exapod
  • Guest
« on: October 06, 2014, 10:49:54 am »
I want to use the MCP1703 in the DFN-8 package and i'm wondering if i can connect the six NC pins to ground for better thermal performance and routing. The datasheet doesn't says nothing about this pins.
Link to datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/22049f.pdf .
Offline HalfSpace
Re: Connection of NC pins in the MCP1703 LDO regulator
« Reply #1 on: October 06, 2014, 09:06:04 pm »
Hi exapod,
The six NC pins can be connected to the thermal pad (EP pin 9) to make a larger dissipation area and better thermal transfer of heat. This pad also needs to be connected to Vss (Ground) as stated on page 11 of the data sheet.
HalfSpace  :)
"He who asks a question is a fool for five minutes; he who does not ask a question remains a fool forever."
exapod
  • Guest
« Reply #2 on: October 07, 2014, 02:20:24 pm »
Thsnks for the answer.
