Author Topic: Connector identification help  (Read 1103 times)
Offline Hornnumb2Topic starter
« on: January 23, 2019, 05:00:02 pm »
I need to replace this lcd connector and have no clue what to order to fit. Thanks Michael
Offline JackJones
Re: Connector identification help
« Reply #1 on: January 23, 2019, 05:07:18 pm »
Looks like FPC connector, 0.5mm pitch. Make sure you get the contact type correct, they can have contacts on top/bottom or both sides.
« Reply #2 on: January 23, 2019, 06:46:47 pm »
« Last Edit: January 23, 2019, 06:50:04 pm by Hornnumb2 »
Offline JackJones
« Reply #3 on: January 23, 2019, 07:03:28 pm »
I'm not an expert on FPC connectors, but I'd think with dual contact ones they would be commoned together, so it doesn't really matter what kind of cable you use.
I'm also not sure how the compatibility is between different types, obviously the pitch is going to be the same, but the two hold-down tabs at the side might not align properly. Hopefully someone who knows better will give some more specific advice.
Offline mariush
« Reply #4 on: January 23, 2019, 07:46:06 pm »
Pull out the flat cable and measure the pitch (the distance between the centers of two contacts) and the number of contacts ... then go at a distributor of components and buy the connector with the right parameters.
Ex.  https://www.digikey.com/products/en/connectors-interconnects/ffc-fpc-flat-flexible-connectors/399
Looks like a 40 pin , maybe 0.5mm , 2.3 cm wide (0.9"?)
There's some text on the retention clip, maybe that would help filter results and find the series of connectors.
