Hey.
I know this message will upset some because "there's no such things as best for all" and such, but please try to understand what I am asking.
During my long ongoing beginner stage, I frequently found myself in need of connecting things. Apart from ribbon cables, I usually use some thin stranded cable, which I crimp with the "proper" connectors at the end, as I think is standard.
Now, this has started for me way back when I was even more a beginner, so I basically used these kits:
- JST-XH (bought on amazon
https://goo.gl/zmdCV6) for pcb/soldered connections
- Dupont (bought on amazon
https://goo.gl/VZuSWT) for breadboard and other things
while to crimp I use
- PA-09 (
https://goo.gl/K69SaB) for the JST
- the Pa-09 and another beast (
https://goo.gl/oDytBq) for the dupont
Since I'm running out of stack of the jst-xh 2 pin connectors, I thought of asking here whether those are the "best" choice I can have and also how can I find them (I do not think they're particularly used, so it was difficult to find the 2pin one at an affordable price in nice quantites). Please bear in mind that I do rarely need more than 100mA and a 1A capable cable/connector is more than enough.
So do you think I have better alternatives (which perhaps are more readily found in other places than amazon) than the jst-xh (which was kinda painful to design pcb around too because many times the component was wrong)? If so what do you suggest? Do I need a different crimping tool?
About crimping tools: crimping the Dupont connectors is really really painful with the tools I have, do you have any recommendations (that won't make me go broke?)
If you read all of this, well thanks a lot, I appreciate that.
I hope this all makes sense.
Cheers
