Author Topic: Consolidating a list of transistors  (Read 7586 times)
Offline StonentTopic starter
« on: October 17, 2013, 10:58:17 am »
I was going to stock up on some transistors at Tayda and just went down the line and picked a little of everything, but since I'm looking at some stuff I don't know about I wanted to paste the list and see if there was anything redundant that could be consolidated.  The first number is the unit price, and the second number was my total based on how many I had selected.
So I'm starting off with 50 each of 2N3904 and 2N3906. I'll probably never use them all, but at least I'll have plenty to pass on to the next generation.
Everything else I selected 10 or 5 based on the price.
I won't be doing anything radio related, probably nothing over an Amp, and probably nothing over 25V.
Maybe consolidate 556/557? MPSA12/13 and MPSA63/64? Or if you see something odd that the average tinkerer would never use or could be just replaced by the 3904 and 3906, then I'd rather put that money into more caps, resistors and diodes which I'm also going to stock up on.
2N3904 PNP General Purpose Transistor $0.02 $1.00
2N3906 PNP General Purpose Transistor $0.02 $1.00
8550SL Transistor PNP 20V 0.7A TO-92 8550SL-D $0.02 $0.20
BC556B BC556 Transistor PNP 65V 0.1A $0.03 $0.30
KSP06 Transistor NPN 80V 0.5A TO-92 KSP06TA $0.03 $0.30
BC550 NPN Low Noise Transistor $0.03 $0.30
KTC3198 Transistor NPN 50V 0.15A TO-92 KTC3198GR-AT $0.03 $0.30
2SC1815 C1815 TRANSISTOR NPN 50V 0.15A $0.03 $0.30
BC557 Transistor PNP 45V 0.1A TO-92 BC557B-KEC/P $0.03 $0.30
2SC945 C945 BIPOLAR TRANSISTORS NPN 50V 0.15A $0.03 $0.30
2SA733 TRANSISTOR PNP 50V 100mA NEC $0.03 $0.30
KTA1266 Transistor PNP 50V 0.15A TO-92 KTA1266Y-AT $0.03 $0.30
KRC103 Transistor NPN 50V 0.1A TO-92M KRC103M-AT $0.03 $0.30
KTC3198 Transistor NPN 50V 0.15A TO-92 KTC3198Y-AT $0.03 $0.30
BC546 Transistor NPN 65V 0.1A TO-92 BC546B $0.03 $0.30
MPSA64 Darlington Transistor PNP $0.08 $0.80
MPSA63 PNP Darlington Transistor $0.09 $0.90
MPSA12 Darlington Transistor NPN $0.10 $1.00
MPSA13 Darlington Transistor NPN $0.10 $1.00
2N5306 NPN Darlington Transistor $0.14 $0.70
« Last Edit: October 17, 2013, 11:05:01 am by Stonent »
Offline dr_p
Re: Consolidating a list of transistors
« Reply #1 on: October 17, 2013, 12:50:43 pm »
If you're just stocking up for future experiments, why the diversity? Just pick some general purpose NPN and PNP (3904/3906, BC547/557 etc.) and maybe some darlingtons.
If you're fixing something, chances are you don't have that exact part anyway, so either you stock up on every part out there (not feasible), or order what is needed for the task. That, of course, if you can't just put a general purpose part in there as a replacement.
Having a ton of equivalent parts can be confusing - e.g. not knowing what the part is beforehand.
Also, NPNs are much more used than PNPs, so you might want to buy 50 NPNs and 20 PNPs.
« Last Edit: October 17, 2013, 12:52:54 pm by dr_p »
Offline c4757p
  • adieu
« Reply #2 on: October 17, 2013, 12:55:29 pm »
Damn! You can do almost anything with PN2222 and PN2907! (I'd recommend them over 3904/3906 because of the higher current capability). Perhaps grab BC550 (and BC560, if they have them) for low noise, if you're doing audio or low-signal stuff. Maybe an NPN RF transistor if they have any. MPSA42 if you want high voltage.
Their prices are good. Mouser seems to be raising their prices higher and higher on through-hole parts - last time I bought transistors, I bought them for $0.06 in singles (I actually bought 100 of each type, don't remember what the price was in that quantity). Now they are almost $0.20! :wtf: I'm running low on 2907s - I think I know where I'm buying them...
« Last Edit: October 17, 2013, 01:45:28 pm by c4757p »
« Reply #3 on: October 17, 2013, 06:43:03 pm »
Buy some MPSA42 as well, high voltage and low current NPN transistors are very useful. Some 2n7000 or VN10km as well are nice low power mosfets.
Offline edavid
« Reply #4 on: October 17, 2013, 07:02:31 pm »
Tayda is good for some things, but not for semiconductors.  You have no idea what quality of parts you are getting, and the prices are higher than a real distributor.
For transistors, Arrow Electronics is usually cheapest.  US shipping is $8, which is more than Tayda, but you can make that up pretty quickly.  Examples:
KSP2222ABU $0.0164
PN2907BU $0.0124
BC550CBU $0.0237
MPSA13G $0.0404
MPSA42G $0.0423
MPSA65 $0.0096
KSP92BU $0.0098
« Last Edit: October 21, 2013, 04:42:14 pm by edavid »
« Reply #5 on: October 17, 2013, 07:52:51 pm »
I have some 2222 transistors already, I would have gotten more but Tayda only had them in metal cans and were a lot more expensive.
They have more transistors than what I posted but in prices where I'd only get 1 or 2 for the price of what I'd get several of already. And I haven't really looked into FETs yet.
So far my shipping is around $2.20 for these transistors and a few hundred ceramics and resistors and some other small parts.
Offline chibiace
« Reply #6 on: October 18, 2013, 07:36:07 am »
tayda is pretty good, check their facebook page for discount codes.
He Who Controls The Spice Controls The Universe
« Reply #7 on: October 18, 2013, 08:53:33 am »
Yeah, missed the last one by 3 or 4 days.  :rant:
« Reply #8 on: October 21, 2013, 08:43:03 am »
Ok using the information from you guys, I've revised my list:
10 MPSA64 Darlington Transistor PNP
$0.08      $0.80
10 MPSA13 Darlington Transistor NPN
$0.10      $1.00
20 PN2222A PN2222 Transistor NPN 40 Volts 600 mA
$0.05      $1.00
20 PN2907A PN2907 2907 PNP 60V 0.8A Transistor
$0.05      $1.00
10 BC550 NPN Low Noise Transistor
$0.03      $0.30
10 BC560 BC560B Low Noise Transistor PNP
$0.08      $0.80
10 MPSA42 NPN High Voltage Transistor 0.5A 300V
$0.05      $0.50
10 MPSA92 PNP High Voltage Transistor 0.5A 300V
$0.04      $0.40
It turned out they did have the 2222 but I guess I searched for 2n2222 instead of pn2222 so I was getting metal can transistors.
Offline JoeO
  • I admit to being deplorable
« Reply #9 on: October 21, 2013, 02:35:11 pm »
Stonent: The prices you have listed, where are you getting them from?
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
Offline c4757p
  • adieu
« Reply #10 on: October 21, 2013, 03:10:05 pm »
They match what I'm seeing for the main prices? :-//
There is a crapton of 2222 variants. 2N2222, 2N2222A, PN2222, PN2222A, MPS2222A, KSP2222A, and that's just the standard PTH stuff. Then you've got MMPQ2222A (quad array, SOIC), PZT2222A, CMPT2222A, MMBT2222A, FMB2222A (dual), KST2222A, PMST2222A in different SMD variations. And watch out for VN2222, which is a MOSFET, and 2SA2222, which is a frickin' PNP..... :scared:
