I bought a used E3610A (old enough to have the original Hewlett Packard branding...) and I'm wondering if someone can outline a procedure which can verify that the unit is fully functional.
As you probably know from Dave's video, this model is rated at 0-8V 3A, 0-15V 2A.
One thing I'm puzzled about is that no matter which max amp setting I use... 3A or 2A, I can dial the voltage from pretty close to 0 (but not quite all the way 0) to 16.xx. I measure the voltage difference across this range with a voltmeter and it's spot on perfect. As a beginner, I don't really know how to safely test the max amp rating. Shouldn't the display max out at around 8V when I have the 2A/3A button depressed? Anyway, that alone is pretty much worth the price I paid, so I wouldn't be too disappointed if the rest of it is busted.
The above "test" was done with the amp dial turned all the way clockwise. I have no idea how to test the constant current feature. I hold down the cc button and dial the right dial, but the right-side display hardly changes and certainly does not go anywhere near 3.00.
