Author Topic: Constant current load not working properly  (Read 1525 times)
Offline jeet55Topic starter
« on: August 29, 2017, 07:49:35 pm »
I built a constant current load using a 741 ic and tip41.
But the voltage across the sense(1ohm) resisitor is staying constant(about 1v) regardless of the voltage adjusted by pot on non- inverting pin.circuit diagram is attached below.plz help me to figure out the problem.
Offline Benta
Re: Constant current load not working properly
« Reply #1 on: August 29, 2017, 08:06:10 pm »
Of course it doesn't. The 741 does not accept signals that close to VEE.
Either give it a negative supply voltage as well, or invest in a rail-rail opamp.
The following users thanked this post: jeet55
Offline danadak
« Reply #2 on: August 29, 2017, 09:26:07 pm »
Generic bipolar 741 does not function off just a 5V supply either.
Regards, Dana.
Offline not1xor1
« Reply #3 on: August 30, 2017, 04:26:24 am »
Regards, Dana.
Besides what has been already written, you (I mean the original poster) cannot connect any opamp to a power transistor pretending to get 1A out; opamp output current might not be enough for driving a TIP41 (depending on opamp feature and that TIP41 hFE).
You should also add a resistor to the base of the transistor (or mosfet or darlington) and probably a capacitor (or RC in series) between the opamp output and the inverting input to prevent oscillations.
And you might need another R+C to dump the parasitic inductance of the cables connecting the load.
You should better look for a proven schematic and read carefully what has been written regarding electronic loads in the https://www.eevblog.com/forum/projects/ section.
« Reply #4 on: August 30, 2017, 04:45:35 am »
So should i use  a mosfet? If yes then which one?
Online Zero999
  • 0999
« Reply #5 on: August 30, 2017, 08:09:09 am »
You should replace the LM741 with the LM358. It will work with its inputs at 0V.
A MOSFET might work but will be more prone to oscillation, due to the high gate capacitance. You could add another transistor to form a Darlington pair, or use a Darlington transistor such as the TIP121 or TIP140.
Another thing you could try is connecting two op-amps in parallel to give more drive current to the transistor. The LM358 contains two op-amps anyway and all that's needed is a couple of extra resistors to help the op-amps share the load.
https://e2e.ti.com/blogs_/archives/b/thesignal/archive/2013/03/26/paralleling-op-amps-is-it-possible
http://www.intersil.com/content/dam/Intersil/documents/an11/an1111.pdf
Offline danadak
