Author Topic: constant current source  (Read 1794 times)
Offline browntTopic starter
« on: February 20, 2018, 09:46:40 am »
assuming a 5 volt supply across a 10K ohm potentiometer, how can i make it so there is a variable 5 volts with a constant current of about 15mA at the wiper?
Offline danadak
Re: constant current source
« Reply #1 on: February 20, 2018, 12:29:02 pm »
What is the load on the wiper ?
Regards, Dana.
Online Circlotron
« Reply #2 on: February 20, 2018, 12:33:34 pm »
Do you mean that there is a 15mA CC load between wiper and ground?
Add a 15mA CC source from +5V to wiper.
Better still, use a unity gain opamp buffer between wiper and load.
« Last Edit: February 20, 2018, 12:35:30 pm by Circlotron »
Offline danadak
« Reply #3 on: February 20, 2018, 12:49:44 pm »
Ap note on current sources and sinks.
http://www.ti.com/lit/an/sboa046/sboa046.pdf
Regards, Dana.
Offline newbrain
« Reply #4 on: February 20, 2018, 12:52:26 pm »
I think until the OP clarifies their question, we are left in the realm of speculations.
What are you actually trying to achieve? In which context and to which purpose?
The following users thanked this post: nugglix, Damianos, brownt
Offline Damianos
  • Country: gr
« Reply #5 on: February 20, 2018, 07:45:53 pm »
This ^ ^ ^ ^
Answers to a vague question can lead to bad results.
The following users thanked this post: Wimberleytech
« Reply #6 on: February 20, 2018, 11:41:51 pm »
Turns out everything works ok, as it seems the load is only 70 microamps and so even at 10K there is sufficient current through the wiper.
thanks
« Reply #7 on: February 20, 2018, 11:43:27 pm »
that is correct, there was i thought a potential 15mA load after the wiper.
add a unity gain buffer, ok thanks.
Add a constant current source? I do not understand. I mean, that was the question, how to make a constant current source.
Offline hamster_nz
« Reply #8 on: February 21, 2018, 01:10:55 am »
With a 10k pot, depending on the position of the wiper you can seen an equivalent of
- 5V with 0 ohms in series (i.e. the wiper at the 5V end),
- 3.75V with 1.875k in seres ((i.e. the wiper at 75% , 2.5k Ohm to +5V and 7.5K Ohm to 0V).
- 2.5V with 2.5k in series (i.e. the wiper in the middle, 5k Ohm to +5V and 5K Ohm to 0V).
- 1.25V with 1.875k in seres ((i.e. the wiper at 75% , 7.5k Ohm to +5V and 2.5K Ohm to 0V).
- 0V with 0 ohms in series (i.e. the wiper at the 0V end)
If you want to stay within 1% of the wiper setting (e.g. so 50% gives 2.5V +/- 25mV) you don't want to be sourcing/sinking more than 0.01 mA from the wiper.
If you are sourcing 70mA, you will be off by about 10% with the wiper in the middle position (around 2.26V vs what should be 2.5V).
Easiest solution is to use a potentiometer with lower resistance (maybe go 1k)
Offline Insatman
  • Country: ph
« Reply #9 on: February 21, 2018, 01:25:08 am »
Here is a ~50uA to 50mA adjustable precision current source I built some months ago.  The only expensive parts are the voltage source, 10 turn pot and the 100 ohm 0.01% Low-tempco resistor.  Truth is a lower tolerance resistor is fine so long as the tempco is very low, as you can calibrate the error out.   The calibrated setting of 50mA was tested to be +/- 2uA after warmup in numerous tests measured with a HP34401A.
« Last Edit: February 22, 2018, 03:43:15 am by Insatman »
Retired Pulsed Power Engineer/Physicist...now I just dabble in electronics
Online Circlotron
« Reply #10 on: February 21, 2018, 07:09:52 pm »
You won’t get useful results supplying a 15mA load with a constant current source.
