So, use the high current secondaries, but connect both center taps to mains earth? This seems intuitively wrong to me, but I guess since the secondary is isolated from the mains, there's no real current flow from there to ground?
And I should leave the isolated ground floating? This seems wrong to me, but again, it's isolated so there shouldn't be any real issue, right?
One more question: There's already a circuit breaker in the UPS case I'm going to use, so I'll go ahead and use it. I assume it'll be best to leave it on the mains side, right?
