So for the 2SK4017 the datasheet only has one stated number for switching time, measured at 10v, but just to try this out, the total is 69ns, so with a PWM frequency of 20kHz, at 3.3v and 1A the switching loss would be about 1mW? Again for RDS(on) it's only measured at 10v and 4v, but even .2 ohm it'd only me 200mW at 1A. With an Rth (ch-a) of 125 total C/W will be 25 degrees? I assume the switching time would be much slower at 3.3v, but I don't think I'll be switching at more than a few hundred Hz.
With the transistor it'd be about 110mW at the same current output, but I can't figure out what the thermal resistance is.
So, theoretically, the transistor is twice as efficient, but deliver a whole .1v less, and for 11 cents less?
