Author Topic: Controlling multiple LED regulators with one potentiometer (Dimming)  (Read 2195 times)
Offline desertgregTopic starter
I'm looking into making a circuit which will control several strings of LEDs.  Each string of LEDs will have its own adjustable constant current regulator like this one from ON Semiconductor:
https://www.onsemi.com/pub/Collateral/NSI45060JD-D.PDF
This regulator has an adjustable output which is controlled by a resistor.  I would like to attach all of my regulators to a single potentiometer or digital potentiometer to allow me to control the brightness of all of the LED strings at once.  My question is, will the circuit work if I attach multiple of these regulators to a single adjustment resistor?
Thanks!
Offline Mr.B
Re: Controlling multiple LED regulators with one potentiometer (Dimming)
« Reply #1 on: April 17, 2019, 02:40:08 am »
With a single adjustment resistor... I would suggest not.
If you were to use individual digital pots, individually addressable by an MCU, it should work fine.
A single pot can then be used as an input to one of the ADCs on the MCU.
Offline Zero999
  • 0999
« Reply #2 on: April 17, 2019, 10:26:49 am »
If you use digital pots, make sure it's on the low side, otherwise the voltage on the pots will be too high.
Why not just use PWM?
If you must use a resistor, then go for the standard op-amp+BJT current sink.
« Reply #3 on: April 17, 2019, 05:41:26 pm »
Its going to be used with a vision system and I was worried that the camera might pick up the flickering LEDs.  Ideally I'd like to have smoothly varying light intensity rather than flickering.  Maybe if the PWM frequency is high enough it will work though.  This current regulator looks promising but it will be a challenge to control multiple regulators due to board space (there's always something!)
Offline grifftech
    • youtube channel
Offline Zero999
  • 0999
« Reply #5 on: April 19, 2019, 08:38:58 am »
I think he wants to control more than two strings.
Here's what I meant. I've only shown two strings, but the op-amp and transistor part can be duplicated for as many strings as necessary.
« Reply #6 on: April 19, 2019, 01:37:41 pm »
Yes this exactly!  I suspect that the part I'm asking about is essentially the equivalent of your op-amp+transistor subcircuit but I'm not sure:
Thats why I was thinking I might be able to control multiple strings with one reisistor.
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #7 on: April 19, 2019, 02:05:20 pm »
currently waiting the pcb of the same purpose... but more like smps, not linear regulation.
Offline Zero999
  • 0999
« Reply #8 on: April 19, 2019, 04:58:11 pm »
Why do you want to use that specific IC? A quad op-amp, such as the LM324, plus a transistor for each string, will probably work out cheaper.
What's the supply voltage? If it's above the maximum rating of the LM324, run it from a voltage regulator made with a zener diode, which could also be used for the control voltage reference.
