Thank you for your answer, sorry I did explain it badly .
This is an attenuator where the audio signal goes from Filter_+ trough U3 and out to Preamp_Out_+
So the U3 act as an electronic pot, managed by the amount of voltage/current that goes trough the LED
Since the H11F3M is not perfect linier, the LM358A do compare U3 and U5 and adjust the U3 so it act much more linier.
When the U3 goes down in resistance, the impedance do also go down, to compensate a bit for that, the U4 goes up in value, so that the total impedance value are about constant.
Yes I did mean "connect (1_out) to +15V, connect (2_out) to lead_to_U4" :-)
Hope that this is a bit better! :-)
