Author Topic: dropped my compartment box with many parts on the floor, should I worry?  (Read 929 times)
Offline exe
  • self-educated hobbyist
Hi!
I was removing my lab and accidentally dropped my box with LDOs, refs, opamps, etc from about 1.5m height on a concreted floor. Do you think something bad could happened to components? I'm not really worried if something died as I can replace it. I'm worried about long-term reliability. The box is a typical AideTek ESD-safe box.
Offline Zero999
  • 0999
Re: dropped my compartment box with many parts on the floor, should I worry?
« Reply #1 on: December 30, 2018, 09:07:43 pm »
They should be fine. I've dropped boxes of components like that numerous times and nothing has been damaged. The components are so light that won't hit the floor with enough force to damage them. If you're very unlucky the package could be damaged, in which case it's possible a wire bond inside has become weakened, in which case you should discard the component, if you're worried about reliability, otherwise it should be fine.
The following users thanked this post: exe
Online Brumby
« Reply #2 on: December 31, 2018, 01:55:11 am »
I agree.
To get any significant impulse force imparted to a component it would need to be solidly mounted to the toolbox case itself.  If you've got components on reels, cut tape or in tubes or loose in bags, they might get a bit shaken, but the forces that matter will not be all that high.
I would suggest that any component mortality that did occur because of this event will be unlikely and indistinguishable from a random failure.
Offline james_s
« Reply #3 on: December 31, 2018, 05:45:50 am »
I wouldn't worry about it. I've had RAM chips damaged by ESD but most jellybean parts are reasonably robust. If they parts were going into a satellite or missile or something I'd say write them off but otherwise don't sweat it.
Offline exe
« Reply #4 on: December 31, 2018, 08:52:30 am »
Thank you very much, guys! I'll report if something weird happened to the parts :).
Offline GreyWoolfe
  • NW0LF
« Reply #5 on: December 31, 2018, 10:33:51 pm »
You should worry.  You will miss picking up 1 IC land legs up that you will step on whilst barefoot.  :-DD
Offline basinstreetdesign
« Reply #6 on: January 01, 2019, 01:49:44 am »
Yep - BTDT   :o
STAND BACK!  I'm going to try SCIENCE!
Online Brumby
« Reply #7 on: January 01, 2019, 03:58:21 am »
Yep - BTDT   :o
I admit to nothing .....  ::)
Offline james_s
« Reply #8 on: January 01, 2019, 06:48:57 am »
I stepped on a TO3 once while wearing only socks on my feet. Ouch.
