Author Topic: Help identifying old TI IC  (Read 307 times)
Offline tinkerer124Topic starter
« on: March 04, 2025, 01:45:39 am »
Hello,
I recently found an old bag of ICs from the 1980s ish and there are many of this chip that I cannot find any info on whether i search any numbers or use the TI lookup tool for part markings.
It reads:
158 2604
BP 851380TS
A 7905 H MALAYSIA
It also has 14 pins.
Does anyone recognize this chip or a datasheet for an equivalent modern one? included is an image.
Thanks in advance for any info.
Offline squadchannel
  • Country: jp
  • deepl translate user
Re: Help identifying old TI IC
« Reply #1 on: March 04, 2025, 01:59:06 am »
I thought it was a Tek parts because of the 3 and 4 digit numbers, but 158- seems to be the part number used for crystal. :-//
MOD:
found in IBM boards
MOD2:
ho-ho-ho!
https://github.com/retrotruestory/ibm
« Last Edit: March 04, 2025, 02:05:55 am by squadchannel »
The following users thanked this post: rsjsouza, fzabkar
« Reply #2 on: March 04, 2025, 02:34:33 am »
Thanks for that! It makes sense as the other 80 ICs in the bag were all hex inverters. Now I just have to figure out what to make with 150 hex inverters…
