Author Topic: 1G74 and 2G74 different  (Read 2176 times)
Offline diyinhk
« on: July 19, 2014, 08:19:16 am »
http://www.mouser.com/ds/2/302/74LVC2G74-352817.pdf
http://www.mouser.com/ds/2/302/74LVC1G74-350009.pdf
I cannot figure out the different from the datasheet.
is it the same part and the different part number is due to history reason :scared:
Offline T3sl4co1l
    • Seven Transistor Labs
Re: 1G74 and 2G74 different
« Reply #1 on: July 19, 2014, 08:02:55 pm »
Idunno, but the markings are even the same... :-DD
Seven Transistor Labs, LLC
Offline CarlG
« Reply #2 on: July 19, 2014, 08:46:46 pm »
I can't find any difference between the NXP '1G74 vs. '2G74 datasheets either, but the TI corresponding datasheets show some differencies. E g TI '1G74 is only specified at 3.3 and 5V for -40 to +125, and for some packages not recommended at all for that temp  range.
My guess is that NXP supplies the '1G74 as a 2nd source for TI. TI and NXP have had some sort of mutual "2nd source agreement" on std logic; however I don't now if that't the case anymore.
The LVC/ALVC nomenclature is a bit confusing since some parts' '1Gxx refers to "1st generation" while other refers to "single gate" (and '2Gxx to "2nd generation" and "dual gate", respectively).
Offline T3sl4co1l
« Reply #3 on: July 19, 2014, 10:40:04 pm »
I always thought it was package size or gate count, i.e., it's a single gate but in a 2G (TSSOP8 or whichever others) package.  But something like a 3G14 is in the same package because it's counting gates.
Not that it has to be consistent.  Numbers are inconsistent all over the damn place.  Look at the x86 instruction set...
