Author Topic: making overdriven components last longer  (Read 3028 times)
Offline Ground_Loop
Re: making overdriven components last longer
« Reply #25 on: March 30, 2020, 05:46:01 pm »
just because you're providing power to a 100W load, it doesn't mean the resistor is dissipating 100W.  Do the calcs and determine what you need.
There's no point getting old if you don't have stories.
« Reply #26 on: March 30, 2020, 06:31:17 pm »
Offline krayvonkTopic starter
« Reply #27 on: March 30, 2020, 08:26:38 pm »
Need a hydraulics expert.
« Reply #28 on: March 30, 2020, 08:41:54 pm »
« Reply #29 on: March 30, 2020, 10:04:12 pm »
That guys have a creamation over his big truck there.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #30 on: March 30, 2020, 10:29:24 pm »
And how do you end with 100Watts in a 1Watt rated device?
Post a realistic problem and not some "omg I'm so random"..
i think its related to this thread where he tried to implement a super wheatstone bridge as linear dropper controlling motor speed and direction..
https://www.eevblog.com/forum/beginners/100watt-400-watt-transistor-to-drive-dc-motor/msg2988810/#msg2988810
if you can relate these 2 threads, everything will come to sense again. i think he want to use 1-3 ohm to drop 100W+ and his problem now is economy (budget).
The following users thanked this post: krayvonk
« Reply #31 on: March 30, 2020, 10:37:11 pm »
Ive got a crazy random idea,  how about we use voltage doublers instead of transistors!!!  =D
Online tggzzz
« Reply #32 on: March 30, 2020, 10:40:03 pm »
Starting to really get a trollish vibe from krayvonk's posts lately.
Yes, I agree.
I remember the times when trolls posted interesting questions :(
It looks like he is on Simon's radar :)
« Last Edit: March 30, 2020, 10:57:11 pm by tggzzz »
Offline free_electron
    • SiliconValleyGarage
« Reply #33 on: March 30, 2020, 10:42:06 pm »
Of course you can do that. Just not for long ...
how do you think they make TVS diodes that can handle 600 watt in a piffling SMA package ? 600 watts , for a few microseconds ... check the datasheets.
  • Country: my
« Reply #34 on: March 30, 2020, 10:51:13 pm »
no one will ever use linear drop to control motor speed today period, motor has varying impedance vs load, try giving some push to your motor in the other thread, the speed will screwed up tremendously or load profile will be so poor. everybody is using some sort of smps, buck regulation or PWM nowadays. at most in AC world they use capacitor to shift AC phase to make an AC motor run i'm not aware though linear dropper in AC motor, i'm not the expert. as i said, get a teacher or learn from others/internet how to do it. if you just pop out with some idea, you can waste your time alot. good luck! edit: but at least now you know how to make a good water heater, thats a good thing though while trying and error. ;)
Offline Manul
  • Country: lt
« Reply #35 on: March 30, 2020, 11:07:54 pm »
One (and possibly the only) useful thing to be said here is that you can parallel resistors (and usually diodes) to get bigger power rating. There are situations when it can be useful. 10x 1W resistors will have a total power rating of 10W.
Offline mikerj
« Reply #36 on: March 31, 2020, 08:53:00 am »
I've got another crazy random idea:  take your childish trolling somewhere else.
The following users thanked this post: tggzzz, atmfjstc
Online tggzzz
« Reply #37 on: March 31, 2020, 09:13:40 am »
An example of that is the "connecting to 0 volts" thread he started with
"cant u just connect to any piece of metal, and its as good as a 0 volts connection?"
Where he is referring to this technique:
https://www.eevblog.com/forum/beginners/connecting-to-0-volts/msg2965014/#msg2965014
« Last Edit: March 31, 2020, 09:16:02 am by tggzzz »
Offline Electro Detective
« Reply #38 on: March 31, 2020, 10:24:45 am »
Say ive got a 1 watt component,  but im putting 100 watts through it.
Is there any way I could stop it from overheating - and still have it in the circuit?
Or is 1 -> 100 way too much...
sorry.  i mean if it was a diode or resistor.
You could wire in series, a ballast and or chain of moist troll accusers that kicks in at 2 watts and beyond, to save the 1 watt resistor  :-+
