Author Topic: converting Volt into dB  (Read 8129 times)
Offline MepakosTopic starter
« on: August 06, 2019, 09:14:46 pm »
How can i convert -20V into dB?
Online magic
Re: converting Volt into dB
« Reply #1 on: August 06, 2019, 09:34:04 pm »
You can't, logarithm is only defined on positive numbers. Decibel scale is usually used to refer to signal power and power is always positive too.
It's you the Decibel Guy again, I see. You would get more sensible responses if you explained what you are trying to calculate and why instead of asking one-liner questions that don't even have a valid answer.
« Reply #2 on: August 06, 2019, 09:46:58 pm »
The question is what is the voltage gain of the transistor in dB?    its -20V! I need to convert that to dB
Offline Kalin
« Reply #3 on: August 06, 2019, 09:50:27 pm »
No it is not -20V. People are not going to do your homework for you. If you want to know how something works or where you went wrong in a calculation many people will help you, but noone is going to just give you answers. Gain is a ratio of input to output and doesn't have a unit.
Sent from my SM-G965W using Tapatalk
« Reply #4 on: August 06, 2019, 09:55:30 pm »
I dont ask for answers just for good advice on how to solve the task.Instead of saying u are not doing my homework which i dont want, u can tell me why -20V is wrong. Ua=20Vss and Uce=Ua.   UCE is the voltage gain of the transistor. So why its wrong.
« Last Edit: August 06, 2019, 10:01:10 pm by Mepakos »
Offline Kalin
« Reply #5 on: August 06, 2019, 10:03:02 pm »
https://en.m.wikipedia.org/wiki/Gain_(electronics)
Read this and report back what you think your gain is and how you think you would convert that to dB
« Reply #6 on: August 06, 2019, 10:18:38 pm »
10log(20/1)=13,01dB.
Offline Bassman59
  • Yes, I do this for a living
« Reply #7 on: August 06, 2019, 11:44:45 pm »
What is the reference to which the -20 V is compared?
Offline chrisl
« Reply #8 on: August 06, 2019, 11:54:54 pm »
That is a power gain in dB. What you are looking for is a voltage gain in dB.
Offline Audioguru again
« Reply #9 on: August 07, 2019, 12:23:56 am »
He is wrongly subtracting the gain number because the transistor inverts the signal. The voltage gain is still 20 times whether it is inverted or not.
A voltage gain of 2 times is +6dB.
A voltage gain of 10 times is 20dB.
Then isn't a voltage gain of 20 times 6dB added to 20dB= +26dB?
Offline bob91343
« Reply #10 on: August 07, 2019, 12:26:06 am »
Strictly speaking, dB has to be power gain.  Output power divided by input power gives the power gain ratio.  Take the logarithm of that (base 10) and multiply by ten to get the result in dB.
However, the situation is more complex, as the definition has been perverted.  One way it's been perverted is to ignore the impedance, thus destroying the meaning.  Another way is to assume a reference that, for some reason, isn't stated.  Example might be sound levels, which are usually expressed in dB but no reference given.  There is an assumption but it's seldom stated.
Standard references are 1 milliwatt, 6 milliwatt, and I forget the sound pressure level, something like 0.0002 dynes per sq cm but don't quote me.  Sometimes 1 Watt is the reference.
For radio communications, the reference is 1 milliwatt.  It's indicated by, rather than dB, dBm.  In a 50 Ohm system, -73 dBm is 50 microvolts.  (Also referred to as signal strength S9)
So try to keep the air clear and be precise in what you mean.
The following users thanked this post: Mr. Scram, magic
Offline radiolistener
« Reply #11 on: August 07, 2019, 01:29:04 am »
because input voltage is Vin = 1 mV AC and output voltage is Vout = 20 mV AC. So, voltage gain is:
Vgain = Vout / Vin = 20 / 1 = 20 times
There is 1 mV AC on the input and 20 mV AC on the output. So we have voltage gain:
Vgain = Vout/Vin = 20/1 = 20 times
You can convert it into dB in the following way:
Vgain_dB = 20 * log10( voltage_gain ) = 20 * log10( 20 ) = 26 dB
This equation 20*log10(x) is actual for voltage and current gain. But when you needs dB for power gain, then you're needs to replace 20 with 10:
Pgain_dB = 10 * log10( power_gain )
For example, if you have 5W on the input and 30W on the output:
Pgain = Pout/Pin = 30/5 = 6 times
Pgain_dB = 10 * log10( 6 ) = 7.7815 dB
« Last Edit: August 07, 2019, 01:54:28 am by radiolistener »
The following users thanked this post: rstofer
Online magic
« Reply #12 on: August 07, 2019, 07:33:15 am »
All true.
And one way it was perverted, and the way OP probably is interested in, is in using dB to refer to voltage gain, without taking into account load resistance and therefore actual power output of the amplifier.
For this purpose, you simply assume that increasing RMS voltage of the signal 20 times increases power 20·20=400 times. So that's 52dB gain. Everybody reports voltage gain that way and virtually no one will say that the gain of your circuit is 26dB.
I think this perversion originates from pro audio, where load impedance used to be assumed 600Ω for some reason (could it be the typical impedance of input transformers in old gear which employed them? no idea). If load impedance is constant and if the amplifier is able to drive it then of course 10x voltage gain produces 100x power gain so this "perverted" rule makes sense.
Also, note that power is always positive. So it doesn't matter if the amplifier is inverting or not. In particular, -52dB gain means that output is 1/400 of the input.
Indeed. If you want to accurately report power output of this amplifier, you multiply output RMS voltage times output RMS current into whatever load will be connected. That's your power which you express in dB referred to watt (dBW) or milliwatt (dBm) or whatever. For example, 20V RMS into 50Ω is 8W so probably about 8dBW=38dBm or so.
If you want to report power gain, you divide output power as above by input power going into the amp and get a unitless (just dB) gain ratio.
« Last Edit: August 07, 2019, 07:40:44 am by magic »
Offline NaxFM
« Reply #13 on: August 07, 2019, 02:44:57 pm »
You can't have a negative gain, the gain is always positive, less than one if it's an attenuation, more if it's a gain.
Also, the gain in this case is a unitless number, because it's a ratio between output and input voltage, so the unit cancels out.
Doing the ratio, the result is negative, in this case for the gain you just take the absolute value and say that the output is inverted
Inviato dal mio Moto G (5S) Plus utilizzando Tapatalk
Offline bob91343
« Reply #14 on: August 07, 2019, 04:31:09 pm »
The broadcasters' use of 600 Ohm stems from telephone engineering.  The telephone systems are traditionally 600 Ohms, most likely derived from practical considerations of building the transmission lines.  They were balanced lines.
Most broadcasters had some link to the telephone system, primarily for long distance relay of programs.  So they had to match the line to avoid reflections (echo).
So the terms dbW and dBm and so on referred to the base, or 0 figure.  (Note that the Bel was named after Alexander Graham Bell, and so the B needs to be capitalized.  The leading d means one-tenth and so is lower case.  The m suffix means milliwatt.  The W suffix means Watt, after James Watt.  Capitalization is important and often neglected.)
Offline soldar
« Reply #15 on: August 07, 2019, 06:28:15 pm »
I don't think that's right.  https://en.wikipedia.org/wiki/Decibel shows negative numbers. 0 dB is gain of unity. Negative gains get negative numbers in dB. WIFI ranges in the -60 dB range. Audio too.
Offline NaxFM
« Reply #16 on: August 07, 2019, 07:25:52 pm »
Well, yes, speaking in terms of deciBels you can have negative gain. I didn't say that, but I was talking about gain expressed as a pure number.
If the ratio is less than one, then the gain in deciBels is negative
« Reply #17 on: August 09, 2019, 03:31:50 am »
Negative gain in dB is not a gain, this is attenuation :)
Offline soldar
« Reply #18 on: August 09, 2019, 06:39:49 am »
Attenuation is the same as "negative gain" and both are correct. Just like a negative profit is a loss, negative growth is shrinking, etc.
A program designed to calculate gain can output the result as "Gain: -20 dB" and it is not incorrect.
Offline mikerj
« Reply #19 on: August 09, 2019, 10:38:10 am »
Exactly, the sign changes depending on whether you refer to a value as a gain or an attenuation.
Offline mikerj
« Reply #20 on: August 09, 2019, 10:42:47 am »
I don't understand this, dB is simply a log scale, it can be used with many different units.  Are you saying that using it for e.g. electric field strength or bandwidth is wrong?
« Reply #21 on: August 09, 2019, 11:41:31 am »
you can use it for different units. For example there is popular unit dBuV (decibel micro-Volt)
« Reply #22 on: August 09, 2019, 02:31:29 pm »
The inverted output of the transistor has no load so its voltage gain is 20 times which is +26dB. It has some output impedance so its output level and voltage gain will drop when it has a load. Then you can calculate its power gain if you want.
edit: Because it inverts, its output phase is negative, not its gain.
« Last Edit: August 09, 2019, 02:34:10 pm by Audioguru again »
Offline pepelevamp
« Reply #23 on: August 09, 2019, 03:44:46 pm »
ya know i figure you don't need to be talking about power or what not to use decibels. its simply a way to talk about scales easily. but the power db versus voltage db - that can be confusing.
Offline bob91343
« Reply #24 on: August 09, 2019, 04:38:26 pm »
I reiterate that decibels are a measure of power ratio.  Any other use is perversion.
Having said that, it's popular culture to use decibels for other purposes, although it's clearly wrong.
As for using it for field strength, etc., it's still a valid power ratio.
We don't say that a 2 Ohm resistor is 6 dB higher than a 1 Ohm resistor.  Decibels are properly used for power ratio.
Saying an amplifier has such and such decibel gain is improper.  But common practice.
The bottom line is that you can be precise or not but if your audience understands your meaning you can get away with however you say it.
