Author Topic: Coplanar Stripline Filter  (Read 1217 times)
Offline RFbeginnerTopic starter
« on: June 02, 2019, 03:11:58 pm »
hello everyone,
i'm designing (or at least trying to ) a coplanar stripline filter, any filter really but online there isn't a lot of informations about that , all the papers i read do not mention how and the formulas used to design the filters, I wrote a matlab code to determine the slot and strip width (using the formula from every book)  and i got 0.769mm for the strip width W and and 0.119mm for Slot width S, which is perfectly confrom to 50Ohm per strip (coupled 100) when i simulated that on CST, I tried various filters i saw online and played with the variables
but the best I got was some losses but nothing that makes a filter, does anyone here have an idea or formulas i could use to design a filter of any kind (BP,LP,HP,BS) knowing that I want it to work between 2 and 3 GHz ?
I would be really grateful.
thanks.
Offline Benta
Re: Coplanar Stripline Filter
« Reply #1 on: June 02, 2019, 05:01:17 pm »
Offline schratterulrich
  • Country: at
    • Elektronik & Layout
« Reply #2 on: June 02, 2019, 07:39:27 pm »
I have realized my first microstrip filters with ANSOFT Designer SV. It's a limited but free student version of a RF CAD software.
Fortunately it includes a very powerful filter design wizard also in the SV version.
You can find the software at http://www.gunthard-kraus.de/Ansoft%20Designer%20SV/
Direct download link http://www.gunthard-kraus.de/Ansoft%20Designer%20SV/English%20Tutorial%20Version/DesignerSV050610.exe
Since it's been some time since i used this software, i don't know if it's compatible to windows 10.
« Reply #3 on: June 03, 2019, 07:37:17 am »
@schratterulrich: thank you ! i'll download it and check it today but it seems that it only does microstrip lines , i'm doing a coplanar stripline CPS ( no ground plane, no vias...) i'll check it more later but thanks a lot.
@Benta thank you but those formulas are for microstrips, i'm designing a CPS coplanar stripline and since its not very used there isn't really any informations about it...
« Last Edit: June 03, 2019, 07:39:31 am by RFbeginner »
  • Country: at
« Reply #4 on: June 03, 2019, 09:33:09 am »
Yes you are right, Ansoft Designer won't support CPS structures.
To be honest, I didn't even know that these filter type exists.
Online tggzzz
« Reply #5 on: June 03, 2019, 09:50:15 am »
Why must it be a stripline filter? What's the unique benefit?
