Author Topic: First time Gerber->PCB order  (Read 1993 times)
Offline dekra54Topic starter
« on: April 08, 2016, 01:42:43 pm »
Hello Forum :)
I'm just a few clicks away from my first order from PCBWay and I thought it would be nice if someone can take a quick look at my Gerber files.
I have never done a gerber export because i'm using Target3001/PCB-Pool and they do it all for you to get your PCB done (But it's quite expensive :( )
I renamed the files as PCBWay expect them but i'm curious if made the right settings for the export or forgot something  ??? .
Thanks in advance  :-+
Dennis :)
« Last Edit: April 08, 2016, 05:28:18 pm by dekra54 »
Offline suicidaleggroll
Re: First time Gerber->PCB order
« Reply #1 on: April 08, 2016, 02:29:20 pm »
Try uploading the gerbers on OSHPark.  You don't have to actually place the order, but their software will parse the files and show you a preview of what it found and what the board would look like, which you can use to check for errors.
Online jpanhalt
« Reply #2 on: April 08, 2016, 02:33:59 pm »
I used to do that with Oshpark too, as I usually ordered from it.   However, I understand that Oshpark no longer provides that service.  Edit: I have not validated that assertion from a member on another site.  On other sites, the free program, gerbv , is recommended.
Link: http://gerbv.geda-project.org/
John
Edit#2: I checked Oshpark and it recommends gerbv (http://docs.oshpark.com/design-tools/gerbv/ ); however, it still seems to provide Gerber viewing service ( http://docs.oshpark.com/submitting-orders/preflight-checklist/ ).  Sorry for the misinformation.   I will flagellate the individual who posted it with a wet noodle.
« Last Edit: April 08, 2016, 03:08:12 pm by jpanhalt »
The following users thanked this post: dekra54
« Reply #3 on: April 08, 2016, 02:43:44 pm »
What do you mean?  They no longer provide previews of the board before you order?  Unless something changed since the last time I placed an order with them about 3 weeks ago, they absolutely still do.
The following users thanked this post: jpanhalt
« Reply #4 on: April 08, 2016, 05:27:53 pm »
I tried it now with multiple Gerber viewers and the one from OSHP I think it looks like it should  :) and I've ordered them now.
Dennis :)
Offline volthaus
  • DIY
    • Volthaus Lab
« Reply #5 on: April 09, 2016, 10:04:38 am »
I've been told http://circuitpeople.com/ is a worthwhile resource for checking your gerbers. I've never used them myself though, but thought I'd mention it.
Let's make it work.. And never give up.
