Author Topic: Looking for some Insight  (Read 2350 times)
Offline Food4MyBrainTopic starter
« on: May 17, 2019, 09:05:37 pm »
Hello,
What would be the best power supply and potentiometer to use to control the speed of this PC fan?
https://noctua.at/en/nf-a14-industrialppc-3000-pwm/specification
I was doing some research online and came across this formula to calculate the ohm rating for the POT. Keep comming up with 30 ohm which doesn't sound right...
https://fearless-assassins.com/topic/36138-making-your-own-computer-fan-controller/
Any help is greatly appreciated.
Offline windsmurf
Re: Looking for some Insight
« Reply #1 on: May 17, 2019, 11:21:58 pm »
Sounds right if you assume your fan minimum voltage is 5v.  Not sure if that fan you chose require 5v pullup on PWM to work.
The following users thanked this post: Food4MyBrain
Offline james_s
« Reply #2 on: May 18, 2019, 12:56:03 am »
Using a potentiometer to directly control the speed of a fan is far from ideal. Why not use a variable power supply, or make a little regulator with a LM317, or one of the numerous dirt cheap buck regulator modules from China, or a PWM fan speed control? Everything you need is available off the shelf for a few dollars.
« Reply #3 on: May 18, 2019, 11:59:29 am »
That's a good point. 5v was an assumption. I will have to reach out to Noctua's support department for that information. Thanks for the input windsmurf.
Appreciate the input james_s. I'm a noob master when it comes too electronics. That was the plan at first to get a variable power supply. I was looking at the Mean Well RS 15-12 Enclosed switching power supply. It looks like a promising power supply but, does it have too much current and wattage for the fan. Also the voltage adjustment is minimal 10.8v - 13.2v.
https://www.meanwell.com/webapp/product/search.aspx?prod=RS-15
« Last Edit: May 18, 2019, 12:01:45 pm by Food4MyBrain »
Offline madires
  • A qualified hobbyist ;)
« Reply #4 on: May 18, 2019, 12:41:35 pm »
That fan has a connector for 4-wire PWM and is designed for 12V at 0.55A max. To control the speed you might buy something like https://noctua.at/en/na-fc1.
« Last Edit: May 18, 2019, 01:38:15 pm by madires »
« Reply #5 on: May 18, 2019, 02:12:25 pm »
That fan has a connector for 4-pin PWM and is designed for 12V at 0.55A max. To control the speed you might buy something like https://noctua.at/en/na-fc1.
I feel like a tard. Nice find madires. I was all over that site and didn't see that. The fan is being used for a DIY project so it needs to be powered by a power supply. Is there anyway to do that? And would the Mean Well RS 15-12 power the NA-FC1? It looks like you need 12v and 5v hooked up to it. If that's the case... how would you achieve that? use a resistor on a 12v leg from power supply to drop the voltage?
Edit : I think i might be looking at it wrong... The NA-FC1 is powered with 12V on the input and spits out 12v and 5v on the output?
pin-configuration
https://noctua.at/en/sip_productfaqnew/productfaq/view/id/215
If you look at the pin-configuration theirs also a RPM speed signal pin. Does that pin have to be used?
« Last Edit: May 18, 2019, 02:19:05 pm by Food4MyBrain »
Offline madires
« Reply #6 on: May 18, 2019, 03:37:13 pm »
You need only a 12V PSU. The MeanWell RS-15-12 should be fine. Yes, the PWM controller creates the 5V PWM signal for the fan (presumably it has a 5V regulator integrated). The RPM signal can be ignored.
« Reply #7 on: May 18, 2019, 06:40:17 pm »
Ok, cool. Thanks alot for your help madires  :)
Offline james_s
« Reply #8 on: May 18, 2019, 07:00:31 pm »
You could also use a salvaged "wall wart" type power supply. 12V is a common type, I find them at garage sales and junk stores, they are often orphaned from discarded electronic gear.
« Reply #9 on: May 18, 2019, 07:11:50 pm »
Is this what your talking about? The fan is 550 ma so this one should be good right?
https://www.kr4.us/wall-adapter-power-supply-12vdc-600ma.html?gclid=Cj0KCQjw2v7mBRC1ARIsAAiw34-zlz47No5jIRxcVnZyIbqTN0NRLgz8L71_moFedcgzU4d9Cxal6iUaAuyEEALw_wcB
Offline james_s
« Reply #10 on: May 18, 2019, 07:18:53 pm »
That ought to work. Do you not already have something like that laying around? I have a whole box full of random wall warts, but then I tend to always save that sort of thing whenever I discard broken or obsolete gear.
« Reply #11 on: May 18, 2019, 07:42:20 pm »
No I don't have one laying around. Im a "minimalist" if that's a word. I don't like clutter. I only keep what I use.
hum... so let me ask you this... The mean well RS 15-12 looks like its capable of powering two fans but it only has one output. Could you have two sets of wires running off the + and two sets of wires running off the - of the power supply to power two NA-FC1's and fans?
Thanks for your time james_s.
Offline james_s
« Reply #12 on: May 18, 2019, 07:44:08 pm »
Sure, you can parallel as much as you want from any power supply, so long as the total current drawn by the loads does not exceed what the power supply is rated to deliver.
Online Old Printer
« Reply #13 on: May 19, 2019, 04:30:01 am »
Minimalist Translates to "Makes a lot of trips to hardware store for every little project". My wife and I argue about it constantly. I buy a bunch of extra nuts and bolts and screws more than I need for a particular project. When it's done she wants me to return the leftovers, I want to keep them in my stash for that next inevitable project. So I don't waste two hours making a trip to Home Depot. I strip everything I can even remotely justify a future need or use. They call us scrounges , I take it as a compliment. :)
Offline james_s
« Reply #14 on: May 19, 2019, 06:02:18 am »
I probably tend to save too much stuff but it certainly comes in handy. Numerous times I've needed one thing or another and have found exactly what I needed in my stash and saved a lot of time which is one of the most valuable commodities there is. I really hate having to go to the store or place an order every time I want to build or fix something. I recently also got a significant sum of money for some NOS components that I had rescued from disposal years ago, I had no idea they were worth so much, I cringe at the thought of all the valuable parts other companies throw out just because someone sees them as clutter and doesn't recognize the value.
Can't stand minimalism, a friend of mine is like that and his house feels completely sterile, it's like hanging out in a furniture store showroom or the waiting room at the doctor's office. Nothing to do, nothing interesting to look at or play with.
Offline Brumby
« Reply #15 on: May 19, 2019, 06:02:53 am »
Minimalist Translates to "Makes a lot of trips to hardware store for every little project". My wife and I argue about it constantly....
Not constantly, but my wife and I had this "conversation" at regular intervals.  One day, however, the hinge on the freezer door broke and I was dutifully called in to fix it.  Then three miraculous events occurred within the next half hour...  #1. I looked at the broken hinge and recognised a piece of scrap metal I had might be just the thing.  #2. I walked straight into the garage and grabbed the box which should have contained it - and it was there!  #3. I had to make one bend (at exactly the right spot) for it to fit and work properly - and I did! :D
The result was a repaired hinge in half an hour.  From that day to this, I have never had that "conversation" again.
Offline james_s
« Reply #16 on: May 19, 2019, 06:11:54 am »
I had a very similar experience. She brought home the control pendant for the dental Xray machine at work, the exposure button had broken and they had a half dozen exams scheduled the next day that they would have to cancel and reschedule if the machine couldn't be fixed in time. I went out to the garage and dug through my boxes of scrap boards on the shelf and found an exact replacement for the tactile button in the pendant. Pulled it off that board, installed it and put it back together, saved the day. She never again has questioned the value of keeping boxes of scrap PCBs.
« Reply #17 on: May 19, 2019, 11:33:28 am »
To each is own. Different life styles mate. My profession I'm always moving from job to job. It's a pain to carry a lot of stuff around with me hoping one day I'll use something. Just to kinda give you an Idea I'm working in the Bahamas on a small island 65 miles due East of Miami. There is nothing here. Anyway appreciate everybody's help.
« Last Edit: May 19, 2019, 01:10:37 pm by Food4MyBrain »
Online Old Printer
« Reply #18 on: May 19, 2019, 02:33:25 pm »
"Minimalist by necessity" gets a pass, kind of like pleading guilty with an explanation in traffic court. :)
« Reply #19 on: May 19, 2019, 03:06:19 pm »
Back to your cave troll  >:D
