Author Topic: Copperless perfboard + wire wrap for RF prototyping?  (Read 6356 times)
Online hendorog
Re: Copperless perfboard + wire wrap for RF prototyping?
« Reply #25 on: September 09, 2019, 09:57:46 am »
Here is a good example of RF lego, will need a fairly fat wallet though!
https://www.xmicrowave.com/
Offline Canis Dirus Leidy
  • Country: ru
« Reply #26 on: September 09, 2019, 12:15:39 pm »
I can't get on with that. I use a Stanley knife, metal ruler and peel the strips off with pliers.
The “classical” technique involves the use of a simple device made of a brass spacer and two old dental drills:
(Photos taken from here)
But of course, there are many options. From spade drills, to homemade burrs from a thin-walled steel tube.
The following users thanked this post: bd139, techman-001
Offline tggzzz
« Reply #27 on: September 09, 2019, 12:28:40 pm »
One other question: I have no single sided board at the moment, but I have some veroboard. Will I have any joy using the copper side of the veroboard as a makeshift ground plane by bridging the tracks with wire, and using dead bug construction on the other side? Or is there too little copper to make this worthwhile?
Depends on the frequencies involved. (Remember, for digital signals, the frequency is defined by the risetime, not the period.)
Any wire is an inductor, rule of thumb 1nH/mm, but a broad flat trace will have a lower inductance.
Any two parallel wires form a capacitor and a transformer.
There are calculators available to estimate the magnitude of the effects.
Online fourfathom
« Reply #28 on: September 09, 2019, 03:24:33 pm »
Of course Amazon has a wide assortment of inexpensive single and double-sided clad boards, perfboards, etc.  Get the fiberglass (FR4) boards, not the phenolic ones.  I've purchased these before and they were fine:
https://www.amazon.com/uxcell-150x100mm-Double-Sided-Thickness-Prototyping/dp/B07R49DXN8/
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline aneevuserTopic starter
« Reply #29 on: October 15, 2019, 04:04:50 pm »
In the light of the postings above, I'm just going to confirm that wireless breadboard is absolutely insidious when it comes to constructing resonant circuits: I've largely ignored the advice above, and I've continued to play around with tank circuits on breadboard, which I've been driving from a sig. gen. through a fixed resistor (I've been swapping in different values to see how it affects Q). These have been behaving largely as expected.
This afternoon, I swapped the fixed resistor for a variable, and I was baffled to see that I was now getting voltage gain from the top of the tank. It took me over an hour to figure out that in fact I'd managed to construct a series LC circuit, where the series C was due to the capacitance between the legs of the variable resistor which were in adjacent rows of the board - in fact, the circuit worked unchanged if I removed the resistor completely, and merely relied on the capacitive coupling between the rows.
This is, on the one hand, painful, and on the other, very instructive.
Offline tggzzz
« Reply #30 on: October 15, 2019, 06:06:57 pm »
Excellent :)
And that's from several points of view, e.g. enquiring, debugging, learning, sharing - and a good base for future experiments!
« Reply #31 on: October 15, 2019, 07:20:12 pm »
Excellent :)
Right. I'm really Mr Theoretical (more at home with the Feynman Lectures than a soldering iron-kinda-guy) and even getting a tank circuit to work reliably at AM frequencies on breadboard is giving me a right schooling in practical circuit construction. And I'm finally beginning to understand why my past attempts at RF circuitry have failed - those stray Ls and Cs the books drone on about really make a difference, kiddies!
Offline tggzzz
« Reply #32 on: October 15, 2019, 07:34:04 pm »
Excellent :)
Yes indeed!
Wait until you look at microwave circuit elements, e.g. stripline filters where the inductors don't have loops and the capacitors are just inductors with a different aspect ratio :)
The combination of theory and practice is more exciting than either on its own.
