Author Topic: IC recognising help  (Read 2608 times)
Offline SolidFloydTopic starter
  • Country: no
  • mmmmmmMechatronics...
IC recognising help
« on: December 06, 2010, 12:51:00 pm »
Well, me, with my absolute just basic skills is trying to figure out why my old man's LCD monitor stopped working.. ;D ;D
The monitor is all black, no life at all, so I suspect the power supply... after some measuring, some googleing I now think the fault is in the inverter, wich is a full bridge inverter board, there is a total of 4 small IC's, that is connected to some high voltage transformers, the pcb around these IC's is miss coloured, may been some excessive heat going on...
I think (I may be totally off here.. ;D) the  IC's are some sort of powertrench mostef's, but I can't find any info about them, the number is P600 AD2T13.. I don't like to put my probes on the pins before I know what's what...
Anybody know of the P600 AD2T13
"If A is a success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut."  - A. Einstein
Online Psi
Re: IC recognising help
« Reply #1 on: December 06, 2010, 09:31:11 pm »
is that everything that is written on the IC?
also check to make sure its 100% correct, sometimes the letters can be easily misread.
  • Country: no
« Reply #2 on: December 06, 2010, 11:06:15 pm »
jepp, 100% sure it's correct..
But after some more troubleshooting, and re-soldering off some bad joints, and the change off one diode the LCD is (for)now working, meaning that these IC's most likely are good...
 ;D
Offline the_raptor
« Reply #3 on: December 07, 2010, 07:27:22 am »
Good job for making a strike against our throw away society.
