I have a few capacitors I'm replacing on an Atari 2600 motherboard. They're coded and it doesn't quite match what I'm familiar with. Specifically, they look like old film caps and have ratings as follows:
- 0.068K 100V
- 0.22M 100VF
- F.1K 100V
The "100V" is fairly obvious (though I wonder about the 100VF). As for the other numbers, I would assume M and K are tolerance references, except the preceding values aren't the usual integer codes. Looking around, I get a few different possible meanings, one being the 0.68, 0.22, and 0.1 values are in an assumed unit (either micro or pico farads) and the M and K are tolerances, or they're a 0.068 Kilofarad and 0.22 microfarad capacitor, respectively. As for the preceding "F" in "F.1K", I've no clue.
Anyway, I figure this is an easy one, but weirdly, I'm having no luck getting a clear answer after searching.
