Hi,I am fascinated by old technology and I understand how gates work, but can anyone point me to some information how gates form larger things, then larger things, then an actual computer or microcontroller, etc.Thanks,Alan
I quite liked this book: http://www.amazon.com/Computer-Organization-Design-Fourth-Edition/dp/0123747503/ref=sr_1_1?ie=UTF8&qid=1406094573&sr=8-1&keywords=computer+design+organizationIt doesn't really go in to "logic gate" detail but it goes through CPU architecture from the lowest levels up.
Quote from: Dago on July 23, 2014, 05:50:26 amI quite liked this book: http://www.amazon.com/Computer-Organization-Design-Fourth-Edition/dp/0123747503/ref=sr_1_1?ie=UTF8&qid=1406094573&sr=8-1&keywords=computer+design+organizationIt doesn't really go in to "logic gate" detail but it goes through CPU architecture from the lowest levels up.
The basic stuff in that one is OK but do beware that a lot of information about actual current CPUs is just plain wrong/misleading.
Here is what I recommend:http://www.amazon.com/Code-Language-Computer-Hardware-Software/dp/0735611319
And this one, its big brother: http://www.amazon.com/Computer-Architecture-Fifth-Edition-Quantitative/dp/012383872X/ref=pd_sim_b_3?ie=UTF8&refRID=1GQMW4DY6YABB2QN30HJ...Probably overwhelming for a complete beginner, but for someone who knows their basic digital logic and want to move further this has everything one could want, IMHO.
(Note that both are in their 5th edition. I wonder if that means earlier editions are cheaper. I suspect most of the content has been quite stable for some time.)
Quote from: amyk on July 24, 2014, 08:47:44 pmThe basic stuff in that one is OK but do beware that a lot of information about actual current CPUs is just plain wrong/misleading.Do you mean wrong as in factual errors? I read the third edition, and some of it was certainly outdated; whenever you read "current CPUs do X" it should be taken with a pinch of salt, but the basic principles still would apply.
Also much of the RISC/CISC stuff is not really true today... given that the authors founded MIPS, it's funny to see how they seemingly present it as the best architecture throughout the book, while all the benchmark results they give are for x86 (which they don't like)
[quote author=amyk link=topic=34206.msg485128#msg485128 dI always imagined it was because MIPS is as I understand it (mostly) free to play with, and that had lead to more academic work about it, didn't realize the connection.But if you are going to be biased towards an architecture there are certainly worse ones to pick..
