I found some schematic. It is not exactly the same as the Corsair is designed, but basically using same parts and concept. So, pretty much the same.
The schematic can be seen in PDF file page15. You can see more stuff on the PCF/PWM control board, there also is a LM358 opamp doing something, but everything else is basically in the same connection. There are more passives added, as the CAP for example I am trying to find out its value.
