From what I have seen, the LT3080 is one of the most popular LDO regulators out there. Less than half a volt of dropout, as opposed to the three volts of the popular LM317. The catch is that there seems to be way less information on how to use it. The only half-useful thing I can find is the attached picture. So, I'd be grateful if someone could explain a few things to me:
1. What is the circle with the arrow in it supposed to be? I know it's some sort of voltage reference, but what exactly does it do?
2. What is the voltage at the noninverting input of the opamp?
3. How can I adjust the output voltage using a voltage rather than a resistor? I'm aiming for 0 to 12 volts, and I only have a 1K pot.
If someone gives me the answer to the first question, I may or may not be able to figure out the other things on my own. Anyways, thanks!
