Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Test load regulation of regulator: just hook electronic load between Vout & gnd?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Test load regulation of regulator: just hook electronic load between Vout & gnd? (Read 366 times)
Jim from Chicago
Regular Contributor
Country:
Power Electronics
on:
January 10, 2022, 06:44:11 pm »
I want to test load regulation of a bucker converter IC on a PCB. Can I just hook an electronic load up to Vout and ground of the IC? Or must I also disconnect the original load of the circuit in the PCB as well?
Logged
TimFox
Super Contributor
Country:
Retired, now restoring antique test equipment
Re: Test load regulation of regulator: just hook electronic load between Vout & gnd?
Reply #1 on:
January 10, 2022, 06:50:50 pm »
One measure of load regulation is to see the delta of output voltage with a delta of load current, so measuring the difference with and without an additional load works for that.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
