Hi!
Recently, I was reading the "Design by the Masters" episode in chapter 5 in the AoE where they describe the input amplifier of the HP34420A nanovoltmeter.
I found interesting how they used a current source to cancel the input bias current, because as discussed in various threads related to building a homemade nanovoltmeter, a low noise preamplifier is much easier to make if one tolerates a high bias current. Thus, might be this concept could be used in a preamp using AD8428s.
However, how does the noise of the op amp used in the current source affect the noise perfomance of the amplifier? They are using a normal op amp in the HP34420A, so presumably it's input noise is somehow not a factor. But then, what are the sources of noise in such a circuit? I at first glance would say that the Johnson noise of the 10Meg resistor is fatal, but this obviously doesn't meet the published specs.
Thanks for any help!
