Author Topic: Tektronix 2232 menu screens problem  (Read 3336 times)
Offline dirty_glamTopic starter
« on: November 06, 2013, 07:26:43 pm »
I bought this oscilloscope a while back but when i bought it I just checked that it turned on and that it showed a signal on the screen using the probe adjuntment lead on the front panel.  A few weeks ago I used it to test a signal generator and it seemed to be working fine but just today I noticed that it should have some information on the screen and show the menu, etc etc but i don't have that, I push the "display",  "Advance functions", etc buttons and nothing shows on the screen.
Is it possible that you can turn on and off this messages from the screen? if so, how can i turn them on? because I don't find a way to do it.  And if it's broken, what is your advice? what should I look for?
Thanks very much
« Last Edit: November 06, 2013, 07:34:44 pm by dirty_glam »
Offline ElectroIrradiator
  • More analog than digital.
Re: Tektronix 2232 menu screens problem
« Reply #1 on: November 06, 2013, 07:51:37 pm »
Check that you haven't turned the beam intensity for the on-screen display down. The scope has a readout intensity control separate from the two trace beams. Locate the outer sleeve of the second rotary control up from the power on button. Turn it clockwise.  ;)
« Last Edit: November 06, 2013, 07:54:29 pm by ElectroIrradiator »
« Reply #2 on: November 06, 2013, 09:21:04 pm »
Thanks, but that's not it.  It was the first thing I checked and it does nothing, clockwise or counterclockwise :-(
« Reply #3 on: November 07, 2013, 01:06:00 pm »
Unfortunately that is the only way I can think of permanently disabling the on screen display. :-// :-BROKE
Offline Switching Power
  • professional hobbyist and design engineer
« Reply #4 on: November 07, 2013, 06:30:45 pm »
If the beam intensity for the on-screen display is not turned all the way down the menu should work.
If it not showing up something is broken and you have your first oscilloscope repair job.
Offline Anks
    • www.krisanks.wordpress.com
« Reply #5 on: November 08, 2013, 10:19:34 am »
Common issue with 22xx scopes. Its normally the lead to the intensity control a bad resistor or the pot itself but that normally is intermittent.
