Author Topic: t68-2 ferrite torroids  (Read 407 times)
Offline p.larnerTopic starter
« on: January 06, 2024, 09:45:21 pm »
can t68-2 torroid cores  be used to wind the coils on for an hf diy stockton bridge?,ie 3-30 Mhz
Offline ZigmundRat
Re: t68-2 ferrite torroids
« Reply #1 on: January 07, 2024, 03:46:22 am »
It should. Keep in mind that as a powdered iron toroid, it takes more turns per micro(milli)henry than the more typical 43 ferrite. For example, the K3NG tuner uses 40 turns on a T50-2 in its bridge.
« Reply #2 on: January 07, 2024, 02:39:43 pm »
thanks,some experimentation req i think then.73
