Author Topic: Does anyone know Japanese?  (Read 7572 times)
Offline alank2Topic starter
Re: Does anyone know Japanese?
« Reply #25 on: July 12, 2017, 08:37:37 pm »
Here is the response--ideas?
Offline CaptainNomihodai
« Reply #26 on: July 12, 2017, 08:39:39 pm »
It responds with:
translate:? not post of alphanumeric characters only is accepted.
I'm guessing it expects a Japanese character encoding or something?
You may have to set up IME (if on Windows).
The following users thanked this post: alank2
« Reply #27 on: July 12, 2017, 08:40:21 pm »
I put some Japanese chars in my text - will that help maybe?
New capcha:
« Reply #28 on: July 12, 2017, 08:43:14 pm »
4059
Offline Ton
« Reply #29 on: July 12, 2017, 08:43:29 pm »
4059
but as already mentioned Japanese IME versions can vrite numbers in 2 different ways (slightly different size)
« Reply #30 on: July 12, 2017, 08:45:04 pm »
Thank you guys!! I believe it accepted it.  You guys are awesome!!  I'm checking with a site that used to make pcb's for retro computers to see if they have a ram/rom/fdd emulator.
Offline metrologist
« Reply #31 on: July 12, 2017, 08:48:03 pm »
isn't it supposed to be two byte characters?
Offline Ton
« Reply #32 on: July 12, 2017, 08:53:46 pm »
Glad we could help
according to original Japanese text it should be Roman numbers, so standard ASCII,
but since it some times didn't work, maybe we ran into some kind of time out in the translation process.
Hope you find what you are looking for, my experience with Japanese is that they often read and write a reasonable English but seldom speaks English.
Offline helius
« Reply #33 on: July 12, 2017, 08:56:48 pm »
There are thousands of Kanji and other CJK characters, which requires multibyte encodings. But there are multiple incompatible coding standards, including Shift-JIS, ISO-2022, UCS-2, or UTF-8. In this case, the web page expects only ASCII numerals from 0 to 9 (the "half-width" characters).
There are multibyte encodings of "full-width" 0 to 9, which would be outside the ASCII repertoire. Probably it is more work to accept those in a web form (the client and server must agree on an encoding). Viewing Japanese web sites often requires the text encoding to be fixed manually, so I take it this is still a problem.
« Reply #34 on: July 12, 2017, 09:17:58 pm »
Glad we could help
I hope they respond, or I'll have to try to translate my English question into Japanese and resubmit that - if that happens I'll be asking in this thread for help with the capcha again.
