Hi everyone!
I just had a stroke of luck getting my hands on some ESD-storage dirt cheap from an old Nokia repair shop that closed. I got some ESD storage containers (
http://www.treston.fi/sites/default/files/294esd_0.jpg) that have a plate on the bottom to connect them to the ground and some ESD storage boxes.
The containers i have connected to each other and the last one to ground. My ground plug has a built in 1M resistor. The boxes however are just on my shelf.
My question is: can I just cover my shelves with conductive material, for example aluminum tape strips, and then connect the that conductive material to the same ground as the containers (the plug has multiple inputs). Would this be the right way to go? I'm guessing that the boxes are meant to be places on a ESD-workbench which would be connected to ground. So basically in my case the boxes would be sitting on conductive material connected to ground.
I have also attached two pictures of the gear i scored if someone is interested. Can only fit about 50% in my "lab" though
