Author Topic: Network cable tester  (Read 1728 times)
Offline mike_mikeTopic starter
« on: February 13, 2022, 12:56:05 pm »
Hello! I would like to build a network cable tester based on 555, 4017, led's and a few more components. I would like to test UTP, STP and FTP Cat5e and Cat6 cables, which uses shielded RJ45 and unshielded RJ45 connectors.
I want to mention that I need led's on both emitter and receiver of the tester, to see if the wires are swapped.
This is the first schematic that I found: http://www.frankshospitalworkshop.com/electronics/diy-lan_cable_tester.html - I used a 9V battery, and I replaced the 47R resistors with 470R resistors.
This is the second schematic:
1. Transmitter: https://danolteanu.000webhostapp.com/testerrj45.gif
2. Receiver: https://danolteanu.000webhostapp.com/receiverrj45.gif
I built the first schematic, and it is working, but then I needed led on the receiver part, and then I built the receiver from the second schematic (2).
I wanted to know if there is possible to make some simple improvements to this schematic ?
« Last Edit: February 13, 2022, 12:58:56 pm by mike_mike »
Offline danolteanu
    • danolteanu.tech
Re: Network cable tester
« Reply #1 on: December 10, 2023, 09:30:54 pm »
I've designed the second schematic.
Build the transmitter and the recevier and it works perfect, no improvements necesarry.
BR/Daniel
The following users thanked this post: SeanB, rdl
Offline liaifat85
  • Country: bd
« Reply #2 on: December 12, 2023, 03:58:20 pm »
Oh.The circuit designer himself is here! I believe, now you'll get the most authentic help regarding your network cable tester.
Offline madires
  • A qualified hobbyist ;)
« Reply #3 on: December 12, 2023, 04:23:18 pm »
Looks very similar to the inexpensive 'LAN testers' sold for 10 bucks (the design is 20+ years old). They are great for checking continuity.
« Reply #4 on: December 12, 2023, 04:52:54 pm »
Yes, the only improvement would be to have a small 8R speaker in the Vdd of the 4017, so that each transition provides a small click, and also if the connections are intermittent you will get noise out of the speaker, telling you of an intermittent joint in the cable.
Also add a 1000uF 25V capacitor across the supply pins of the 555 timer, which will help with stability as the 9V battery ages.
