Author Topic: DIY Desoldering Tool Using Compressed Air / Ventura?  (Read 434 times)
Offline GrievousAngelTopic starter
« on: December 01, 2024, 12:11:58 am »
Many of the more expensive desoldering tools use positive compressed air applied to a ventura. One of the main advantages of using compressed air verses a vacuum pump is the comporessed is in a accumulator (~80 psi at low flow rates) waiting for a sol valve to shift. All this offers a near instantaneous vacuum to lift the molten solder up and away! While the vacuum pump has a significant rise time given the pump motor starts from an off state, i.e., zero vacuum pressure since no accumulator is present.
You locate an inexpensive desoldering iron (~ $16 - $20) with a 'piggy-back' container to hold the removed solder. Some use a flexible ball that you squeeze & release. The vacuum hose would replace the squeeze ball in this example.
If the vacuum pressure & flow rate was larger, the typical clogging and frequent cleaning would decreased significantly.
Has anyone tried this approach to desoldering? Any other suggestions?
Later, Billy
Offline Andy Chee
Re: DIY Desoldering Tool Using Compressed Air / Ventura?
« Reply #1 on: December 01, 2024, 02:15:09 am »
I think poor desoldering is due to lack of heat, not lack of suction.
Offline johansen
« Reply #2 on: December 01, 2024, 03:58:00 am »
I desolder lots of crap by using a small tube and blowing the solder out of the joint.
Offline Analog Kid
« Reply #3 on: December 01, 2024, 05:02:12 am »
How 'bout a combination soldering iron/airbrush setup of some kind? I have a small compressor that I use with my airbrush; maybe could rig it up with a nozzle and a small valve placed near the soldering iron tip to just blow the crap away. (I've done that by just blowing with my mouth, but it's not very aim-able or controllable.)
Online Xena E
« Reply #4 on: December 01, 2024, 10:20:32 am »
Great way to reclaim components.
Bad way to repair a board. Solder particles and dust get under components, between leads, and into switches/pots.
The following users thanked this post: tooki, jerryk
Offline Terry Bites
« Reply #5 on: December 01, 2024, 03:06:03 pm »
I once toyed with the idea of converting a foot pump into a vacuum source. Heat and stomp.
Anger out, solder out. Win win.
The following users thanked this post: Xena E
