Author Topic: [.asc file attached] Problem creating a new component in Multisim  (Read 675 times)
Offline MichelemmikeTopic starter
I'm trying to create an SCR in Multisim using the manufacturer's Spice model. The problem is that the newly created SCR works like a diode, no matter what the gate signal is.
Here's the datasheet: https://www.vishay.com/docs/94391/vs-70tpspbf.pdf
Here's the Spice model: https://www.vishay.com/docs/96761/vs-70tps16.pdf
Here's a video about me creating the new device: .
For a comparison, I designed the same circuit using a Multisim-included SCR, which works fine. At 5:31 you can see the voltage across the resistor in both cases.
So I really don't know why it doesn't work. Any thoughts?
Thank you
Michele
EDIT: the LTspice .asc file of the circuit is attached
« Last Edit: April 27, 2022, 02:21:21 pm by Michelemmike »
Offline tepalia02
  • Country: bd
Re: Problem creating a new component in Multisim
« Reply #1 on: April 27, 2022, 10:51:05 am »
Hi, did you follow all the steps shown here?
« Reply #2 on: April 27, 2022, 12:16:44 pm »
I used the component wizard with the manufacturer's spice model. The video you sent is about creating a new component from scratch.
« Reply #3 on: April 27, 2022, 02:19:04 pm »
I replicated the same circuit in LTspice. What I get is a bunch of random spikes.
The .asc file is attached.
