Author Topic: Additional scoping safety with GFI (Ground Fault Interrupter)?  (Read 1015 times)
Offline ollihdTopic starter
    • HeyDay Pro
I have a question about oscilloscope safety. My scope is connected to a grounded power strip with surge protection. I scope with high voltage differential probes when the DUT is not floating. I mainly scope low voltage circuits, but occasionally some high voltage ones also.
My question is: would I be adding additional safety to my way of working if i connect the power strip behind a GFI?
Offline wraper
  • Country: lv
Re: Additional scoping safety with GFI (Ground Fault Interrupter)?
« Reply #1 on: March 02, 2017, 09:31:01 pm »
You will get additional safety only if you power DUT through the GFI. Connecting or not connecting the scope itself, won't change anything.
    • HeyDay Pro
« Reply #2 on: March 02, 2017, 09:32:59 pm »
Thanks for the reply. Starting to make sense. DUT would automatically be behind the GFI since it draws from the same power strip.
