Jack with switched GND aren't the most common, and I use small 3.5mm smd jack sockets. I drew this schematic can I get your opinions on it?
It uses RC4580 opamp as a buffer to drive the line/headphones out, then mix the stereo signal into mono with two resistors, the goes into the amplifier IC for the speaker.
However I'm not sure about the impedance of the FM8002A input, if you look on the first pic I posted you see the FM8002A expects a 0.39uf cap and 20Kohm resistor in series with its audio input.
Here it's placed after the big 220uF DC blocking caps, and there are the two 10k resistors to mix L/R channels. Will the amplifier see the input impedance as 5K ? (two 10k in parallel) Is the capacitor size a problem ?
