My best advice is to try to make it a bit more compact, there's lots of wasted space where the traces are, and also while in many cases length matching is a good thing and when you are dealing with high speed data that needs to get to the same place at the same time, it doesn't seem like its needed in this case, lastly I would add a flooded ground plane on both layers to keep the noise low and to add heat sinking for the ground pad on your main IC (Sorry I cant see the name underneath the traces).
As an after thought, I always like to make 3 - 5 versions of the same board, I always seem to make the next one better than the last. I would urge you to do the same as it gives you extra practice and the end result its usually better than the first try
. Also, try to use only one layer. It might be impossible and that's ok, but its always a good idea to challenge yourself to route smarter and reduce layer count.
Good luck! :
