Author Topic: Samplig rate and SNR  (Read 1137 times)
Offline rakeshm55Topic starter
« on: November 09, 2015, 11:17:24 am »
Recently i came across
""Oscilloscope signal-to-noise ratio can best be improved by:    Increasing the oscilloscope's sample rate ""
in Friday Quiz published in eetimes....link as given below
http://www.eetimes.com/author.asp?doc_id=1328192&page_number=5
How can sampling rate affect signal to noise ratio??"Can some one help me understand the concept.......My understanding is limited to SNR affected by adc resolution.....
Offline rs20
Re: Samplig rate and SNR
« Reply #1 on: November 09, 2015, 11:38:32 am »
My guess is that they're referring to Hi-res sampling mode; where consecutive samples are averaged together to achieve noise reduction (see here). In principle, with a higher sampling rate, hi-res mode can do more averaging and thus reduce noise.
Offline scatha
« Reply #2 on: November 09, 2015, 12:00:25 pm »
Oversampling then filtering reduces quantization noise, which could be what they are referring to.
