Author Topic: Crystal load capacitance and using the wrong caps  (Read 6572 times)
Offline PeteAUTopic starter
« on: December 25, 2013, 08:16:31 am »
Hi Guys,
I reordered some crystals for an existing design but this time they're a different brand/make and I just realised a totally different load capacitance of 30pF. (Element14's product page says so, but it's not in the datasheet per se, depends on manufacturer order code?).
I'm using these crystals with a microcontroller and 27pF caps, which I realise are now the wrong value.
The crystal wants to see 30pF and I'm giving it ((27*27)/27+27)+5 = ~ 19pF.
Can I get away with it? How bad will it be? If I build 100 units, could some of them refuse to fire up?
Offline mrkev
  • Country: cz
Re: Crystal load capacitance and using the wrong caps
« Reply #1 on: December 25, 2013, 12:55:52 pm »
Differences of few % in this case doesn't matter. Those capacitors don't need to be very precise, because they are used just as "kind of load", lowering the amplitude on xtal. So 27pF vs 30pF is completely OK. You could check on oscilloscope what would f.e. 10pF vs 47pF do.
I don't really get where you came up with this value. If it's standard connection on each side of xtal, you can't calculate it like this...
alm
  • Guest
« Reply #2 on: December 25, 2013, 03:19:22 pm »
Note that even a good 10x scope probe will have a capacitance of approximately 10 pF.
Seems pretty standard to me. Compare this appnote, page 2. Note that Fig. 6 gives a typical curve of load capacitance vs (relative) frequency.
Offline Hatimoooo
« Reply #3 on: December 25, 2013, 09:23:43 pm »
Hello.
You can check your microcontroller's datasheet. I've seen some before and they offer an interval for crystal capacitors, check if yours are in the interval
Offline mrkev
  • Country: cz
« Reply #4 on: December 25, 2013, 11:51:20 pm »
Well ok, my fault :palm:. I didn't get the jump from parallel capacitors to overall load capacity (as it's not really clear if those 30pF are ment to be load capacitance or two capacitors that this manufacturer recommend to use).
« Reply #5 on: December 26, 2013, 12:03:47 am »
I think my post wasn't very clear :) Here is the excerpt from farnell.
So from that, I assume I _should_ be using two 48pF caps, but that seems really high, you don't see that every day. Am I on the wrong track?
« Last Edit: December 26, 2013, 03:19:14 am by PeteAU »
Offline mariush
« Reply #6 on: December 26, 2013, 01:51:03 am »
Where do you see 54pF, how do you figure that out?  It says right there, 30 pF load capacitance...
Offline sleemanj
  • Professional tightwad.
« Reply #7 on: December 26, 2013, 02:44:40 am »
Indeed, according to the formula in the appnote alm linked for calculating load capacitance,
in order to get a 30 pF load capacitance, one should have 50pF capacitors.
Offline mrkev
  • Country: cz
« Reply #8 on: December 26, 2013, 10:31:50 am »
Well, I would do this. Take one board with 27pF caps, check the frequency after the oscilator (if you have uC, just use Timer/counter output or something) with good log. counter. Then mout another 27pF caps at the top of caps that are already there (so they are parallel). Check frequency one more time. If you see big improvement, change the caps; if you don't see any improvement, don't bother...
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #9 on: December 26, 2013, 12:02:32 pm »
A good guideline is that a "happy" xtal oscillator will have a similar amplitude on each pin. Remember you need to use a low capacitance scope probe to test thos - x100 probe, or put a 10M resistor on the end of a x10 probe
Day Job: Mostly LEDs
