Author Topic: Lenovo Thinkpad charger with magsafe 2 cord?  (Read 7434 times)
Offline swimllamaswimTopic starter
« on: November 17, 2016, 02:49:22 pm »
My magsafe 2 charger broke, the cable frayed and the pad ripped off while trying to desolder the cord from it. So I looked up the specs of a magsafe 2 charger and saw that it matches up with Lenovo thinkpad chargers (the old style, with the barrel connector). If I spliced the magsafe 2 cable onto it, would that work? The only difference I've seen is that the thinkpad charger is 90w instead of 85w like the magsafe charger. Am I completely off base here?
Online linux-works
    • netstuff
Re: Lenovo Thinkpad charger with magsafe 2 cord?
« Reply #1 on: November 17, 2016, 03:00:33 pm »
thinkpads have a 3 connector jack.  there's a programing resistor there that the laptop senses.
research that, first.
Online Monkeh
« Reply #2 on: November 17, 2016, 03:02:43 pm »
In a word, no, you can't just patch the cables together and go.
E: well, maybe. But.. don't. Just get the right charger or fix your soldering job.
« Last Edit: November 17, 2016, 03:05:17 pm by Monkeh »
« Reply #3 on: November 17, 2016, 03:03:16 pm »
Oh I know but it still has two wires in the cord, just like the magsafe charger. I have about a hundred of these Thinkpad chargers so I took one apart.
Offline helius
« Reply #4 on: November 17, 2016, 04:22:07 pm »
See http://www.righto.com/2015/11/macbook-charger-teardown-surprising.html
The Apple charger's cord has 4 wires (+, -, enable, and ground), not 2.
Online Monkeh
« Reply #5 on: November 17, 2016, 06:29:33 pm »
Err, where are you seeing those magical extra conductors?
Offline RGB255_0_0
« Reply #6 on: November 17, 2016, 06:41:07 pm »
Looking at this https://www.ifixit.com/Guide/MacBook+Power+Cord+5-Pin+MagSafe+Connector+and+Cable+Replacement/21842 I don't see why any (correct) wattage power supply wouldn't work since the MagSafe connector has all the goodies inside such as the chip that talks to the SMC.
Your toaster just set fire to an African child over TCP.
Offline CJay
« Reply #7 on: November 17, 2016, 06:43:07 pm »
Umm, no, they really don;t use a resistor to 'program' anything.
What they do have is an electronic ID chip that's connected to the central 'needle' pin in the barrel connector.
The system communicates with that chip to identify the charger type and allow the BIOS to verify the charger capabilities and that it's a genuine part.
For once Apple were behind the curve when it comes to ripping off customers as that scheme has been used for years by Dell, HP, Lenovo and no doubt others too.
Online Monkeh
« Reply #8 on: November 17, 2016, 06:48:33 pm »
http://www.thinkwiki.org/wiki/Power_Connector#Signal_Pin
http://www.thinkwiki.org/wiki/Power_Connector#Signal_Pin_2
Offline CJay
« Reply #9 on: November 17, 2016, 07:37:48 pm »
*hangs head in shame*
I take it back, I had been wrongly informed that Lenovo used the same or similar scheme to Dell and HP
Online Monkeh
« Reply #10 on: November 17, 2016, 07:40:24 pm »
Only in that they restrict performance or charging based on the connected adapter. Some people take that as a great injustice and a ploy to prevent the use of third party chargers.
Those people are idiots.
Offline LA7SJA
  • Country: no
  • Acting user manual reader & forum search engine
« Reply #11 on: November 17, 2016, 08:40:16 pm »
This is one of the best explanations of how the "magic" Apple charger circuit works:
Johan-Fredrik
"If at first you don't succeed, skydiving is probably not for you"
