I am measuring with an advantest tr5823,the specs are:
Description
Report Item
OCXO-10MHz rate reference source:
Current consumption: preheating stage <750mA, working stage <300mA
Preheating time :≈5 minutes
Calibration accuracy :±001Hz
Frequency stability :5e-12
Output level :dBm: 10dBmt2dBmas09;
VRMS:07071V@5022:
VPeak: I.0V@502:
VP-P:20Va502.
Output impedance :50Ω
Interface type :SMA outer screw inner hole
Product Usage: constant temperature 0MHz ultra-low phase noise, frequency reference module, frequency reference source,OCXO rate reference source, used for sound system, decoder, shortwave radio, frequency meter, signal source and other instrument reference.
as its so small with tiny resistors, I am thinking of doing a rebuild on a new custom pcb using a tl431.
