I need to send a 9.5-12V constant signal into a SCART connector (apprently 1KOhm min, 10kOhm nominal). Since I have only 5V on the board I tried to simulate a Dickson charge pump using the timer on the microcontroller inspired by Dave's Microcontroller Voltage Doubler video (
I4ED_8cuVTU on youtube).
I made a
simulation to find proper capacitors values before testing on breaboard, and though I found that 1 to 10uF and 1k to 1MHz give the proper output after 1 to 10ms, the current drawn on the pin is very high. I set the ESR to 5Ohm (is this a realistic value for lcsc / aliexpress 0603 1 or 10uF ceramic capacitors ?) and it dropped to a couple hundred mA (for about 20ųs only).
Should I be concerned with the initial current drawn during the first few cycles ? Do I need to add a serie resistor on the clock outputs ?
Thank you,
j.
