Author Topic: Touch panel  (Read 1647 times)
Offline abdullahsebaTopic starter
Touch panel
« on: September 30, 2014, 12:51:22 pm »
were can you buy a tablet sized capacitive touch panel 7in or 10in with a HID USB controller?
This is my right hand this is my wrong hand
Offline sacherjj
Re: Touch panel
« Reply #1 on: September 30, 2014, 01:53:46 pm »
Most common capacitive TPs in typical tablet formats have an I2C data output from the panel chipset.  I've only seen TPs integrated with an LCD with custom USB connections for USB touch monitors.
Offline Ton
Re: Touch panel
« Reply #2 on: September 30, 2014, 09:19:31 pm »
Hi abdullahseba
You could try Arrow embedded http://www.arroweurope.com/.
I got some displays and capacitive touch in 7" from them for prototyping a machine HMI, I don’t know about low volume, but I got 3 pcs as initial samples for the design phase.
the touch driver board can be ordered with USB or I2C interface
and the touch driver is compatible with linux 2.6 kernel
just checked the website, and they have 155 items identified as touch screen - so it might be worth to give them a call, might not be cheap though
br Ton
Offline IconicPCB
Re: Touch panel
« Reply #3 on: September 30, 2014, 09:51:06 pm »
Olimex from Bulgaria have the young maiden's dream.
EDIT: in both a seven inch and a ten inch variant
« Last Edit: September 30, 2014, 09:52:38 pm by IconicPCB »
