Author Topic: Shearching audio amplifier schematic  (Read 1711 times)
Offline dbernotasTopic starter
  • Country: lt
« on: January 06, 2021, 02:32:58 pm »
Hello
I have a problem and I am hoping someone could help me :)
I am looking audio amplifier schematic. I know there are tons of them on internet, and this is one of problem: I have no idea what to choose...
I will be building it my self, so it should be an easy one to make.
I will use it to power up 2x3wats (4 ohms) speakers and one 6w 6(ohms) "subwoofer". All speakers are from old 2.1 audio system used with my old pc.
I would like to make it stereo and it would be nice to regulate "bass" level separately.
Offline bob91343
Re: Shearching audio amplifier schematic
« Reply #1 on: January 06, 2021, 08:27:17 pm »
It's a bit ambitious for a homebrew project.  You can find a unit that does what you need and look at the diagram.  But there are too many specifications for a simple answer.
Offline Le_Bassiste
« Reply #2 on: January 06, 2021, 09:04:44 pm »
Hello
it really depends on how comfortable you are with designing (calculating)  and troubleshooting electronic circuits.
maybe, the lower powered (exactly the range you specified) integrated audio amplifiers are a good starter for you.
for example, TDA2003. super simple circuit and dead cheap.  a single one for each L and R, and another two in "bridged" configuration for the subwoofer should do for your purpose.
have a look: https://www.circuitbasics.com/complete-guide-to-build-a-10w-amplifier-with-the-tda2003/
« Last Edit: January 06, 2021, 09:06:52 pm by Le_Bassiste »
An assertion ending with a question mark is a brain fart.
The following users thanked this post: dbernotas
Offline Larryc001
« Reply #3 on: January 07, 2021, 06:08:02 am »
There are lots of kits for sale on the internet which have all parts and instructions for probably less than buying parts separately. Great for beginners. Here is one I particularly like because it looks kinda trick.
https://www.ebay.com/itm/Single-End-6J1-FU32-Tube-Amplifier-Kit-HiFi-3W-3W-Power-Amp-Audio-Amplifier-Kit/353344738491?hash=item5244fcd4bb:g:WNcAAOSwS3Ff9oBQ
Offline andy3055
  • Country: lt
« Reply #5 on: January 07, 2021, 08:44:55 am »
Thanx all for replaying.
I will be trying to do what Le_Bassiste suggested  :)
Seems interesting and not too complicated  8)
Will be updating on how its going :)
  • Country: lt
« Reply #6 on: March 26, 2021, 12:09:14 pm »
Hello again good people.
I am back. After some long trials and errors i made some progress :)
I took schematic from this site and made some changes
https://xtronic.org/circuit/amplifier/circuit-power-audio-amplifier-with-tda2030-2-1/
My approach looks like this
https://drive.google.com/file/d/1zsTLtkXBN6R8aFa591uhQWQGm2qU3U-l/view?usp=sharing
Difference is that I replaced TDA2030A amp circuit. I took it from datasheet.
And as for my power supply I didn't have transformer with center tap, so I found schematic how to make power rails.
And now i have some question:
  • Is it good to use such power supply without center tap transformer?
  • I use "pre AMP circuit" NE5532, but I don't understand why it is used, as I can hear my bass speaker is much more louder than left and right speaker. Maybe I could/should this kind of pre amp circuit on left and right channel ?
  • how to make effective low pass filter, because now my subwoofer sounds like big loudspeaker, I can hear great amount of mid range sounds?
  • Is it necessary/recommended to add electrolytic capacitor in series to speaker to save from dc voltage? What would be cons and pros ?
Thank you in advance.
Offline mariush
« Reply #7 on: March 26, 2021, 12:30:02 pm »
I'd suggest going up to TDA2050, as it allows you to go with as low as 9v (so you can power it from a 12v power supply, or a laptop adapter 16.5 .. 18.5v if you want to) and it's dead simple to use.
You can still buy clones from lcsc for under 50 cents each:
1. HGSEMI TDA2050TB : https://lcsc.com/product-detail/Audio-Power-OpAmps_HGSEMI-TDA2050TB_C434516.html
The datasheet also contains very clear schematic and explanations : https://www.st.com/resource/en/datasheet/cd00000131.pdf   (I've also attached it to this post)
The clones probably won't have same maximum power and will probably have smaller transistors inside so I probably wouldn't power them with near the maximum voltages,  but should still be good for 20-25 watts.
Here's a DYI project with it,  though they use the split power supply version, using a transformer to get negative and positive voltages : https://diyaudioprojects.com/Chip/DIY-TDA2050-Hi-Fi-Chip-Amplifier/
Keep in mind that these chips are only around 65-70% efficient, so you really need a heatsink on them if you give them lots of voltage and aim for high wattage.
Offline pqass
« Reply #8 on: March 27, 2021, 12:10:10 am »
In case you are not aware, a wonderful resource for all things audio can be found here: https://sound-au.com/
The project descriptions and articles are thorough.  A very good start for a beginner.
I'm not affiliated; just a happy user.
