Author Topic: Doorbell Signal to Turn on 12v Relay help please!  (Read 12594 times)
Offline zastilTopic starter
« on: August 01, 2012, 06:58:09 pm »
I have a 555 timer circuit that allows on/off option to turn on a relay which is working fine by connecting the 2 wires coming from the  555 each time turns on and off all is okay even using a 9v battery to power the 12v relay.
My problem is that I want to be able to use a cheap doorbell I got to send the 3v signal to a transistor to allow the 2 wires coming from the 555 so when doorbell is pushed the 3v maybe less is sent from the device to the transistor to allow the 2 wires to connect.
I will take some photos to show you this on a breadboard working and what trying to add!
I hope you can solve this for me as I can get it working sending the 9v to the transistor to send it on/off but the 3v seems todo nothing.
Wayne
Images are at https://plus.google.com/photos/108816590701606354526/albums/5771786186820109713
« Last Edit: August 01, 2012, 07:21:11 pm by zastil »
Offline KTP
Re: Doorbell Signal to Turn on 12v Relay help please!
« Reply #1 on: August 01, 2012, 07:19:37 pm »
Am I the only one a bit confused here?
Can you draw a crude schematic of what you have right now?  And the part number of the transistor...
« Reply #2 on: August 01, 2012, 07:22:55 pm »
Transistor is BC557 (pNp) I also have BC547 (nPn)
« Reply #3 on: August 01, 2012, 07:25:23 pm »
is the 555 on/off circuit
Relay Toggle Circuit Using a 555 Timer
This 555 timer circuit below toggles a relay when a button is pressed. Pins 2 and 6, the threshold and trigger inputs, are held at 1/2 the supply voltage by the two 10K resistors. When the output is high, the capacitor charges through the 100K resistor, and discharges when the output is low. When the button is pressed, the capacitor voltage is applied to pins 2 and 6 which causes the output to change to the opposite state. When the button is released, the capacitor will charge or discharge to the new level at the output (pin 3). The parts are not critical, the resistors can be somewhat higher or lower, but the 2 resistors at pins 2 and 6 should be equal values, and the resistor connected to the cap should be 10 times greater or more.
Advantages of this circuit are the large hystersis range at the input which avoids false triggering, and only a few parts are needed for construction. One disadvantage is the relay may be engaged when power is first applied. To solve this problem, you could tie the reset line (pin 4) to another resistor/capacitor combination with the capacitor at ground and the resistor at the +V point. This will cause pin 4 to be held near ground for a short period which will reset the output when power is applied.
The 100 ohm resistor and 100uF capacitor serve to filter noise on the supply line if the circuit is used in a automotive application. They may not be necessary. The circuit may work well without those parts.
« Last Edit: August 01, 2012, 07:35:51 pm by zastil »
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #4 on: August 01, 2012, 07:50:37 pm »
So you're looking to replace the switch in that circuit with a transistor that is turned on by a 3v output on the doorbell when activated?
Chet
Paid Electron Wrestler
« Reply #5 on: August 01, 2012, 09:48:37 pm »
Yes exactly that!
Offline KTP
« Reply #6 on: August 01, 2012, 10:25:39 pm »
It is maybe not so easy to do what you want with one transistor (at least I am too sleepy to see the obvious simple solution).  You have the 555 wired as a simple state machine that toggles the state based on a input action (pressing the switch).  The 555 is more like a S R flipflop...if it were a JK flipflop this would be easy...just turn it into a T flipflop.
Let me think on this a second.  We do have that unused discharge mosfet on pin 7....
« Reply #7 on: August 02, 2012, 09:55:52 am »
wow thanks for looking at this for me. I thought transistors were supposed to take a small current to release a stronger one, but I am very new to them.
Offline T4P
  • Country: sg
    • T4P
« Reply #8 on: August 02, 2012, 01:10:42 pm »
Release? No not release. Magic doesn't happen in electronics
They act as switches.
Offline KTP
« Reply #9 on: August 02, 2012, 01:24:30 pm »
Here is my solution:
BTW this is the worst schematic I've ever draw.
How will that solution ever change the state from low output to high output?
Offline Monkeh
« Reply #10 on: August 02, 2012, 01:35:08 pm »
You mean the worst schematic you've ever taken off the internet, badly modified, and stripped the original author's name from then posted as your own.
Offline Monkeh
« Reply #11 on: August 02, 2012, 01:39:48 pm »
There's plenty of room.
Offline KTP
« Reply #12 on: August 02, 2012, 02:03:24 pm »
I repeat.  What happens in the case where the 555 output is low such that the capacitor is discharged.  Activating the transistor with 3V will not pull pin 2 and 6 low to change the 555 output to high as desired.
You need an analog switch or a buffer with an enable line.
Offline T4P
  • Country: sg
    • T4P
« Reply #13 on: August 02, 2012, 02:23:34 pm »
Well at least include the actual author itself next time
Offline PA0PBZ
« Reply #14 on: August 02, 2012, 03:08:45 pm »
Since the emittor is at 6 volts nothing will happen either way with the base at 3 volts...
Offline G7PSK
  • It is hot until proved not.
« Reply #15 on: August 02, 2012, 03:17:48 pm »
Where on the door bell board do you propose to get this 3 volts from, the speaker?.If you have 3 volts why not have a 3 volt relay, there are lots of 5 volt rated ones and they will mostly work down to 3 volts or less in the small sizes. There would then be no need for the 555.
Offline KTP
« Reply #16 on: August 02, 2012, 03:58:20 pm »
The OP wants a 3V controlled t flipflop, which can't be made from a 555 without extra parts.
I like the suggestion of using a relay or some other circuit.
« Reply #17 on: August 02, 2012, 06:14:49 pm »
So in all I would need 2 relays? 12v/240v and 3v to 4v ugh so why are transistors used.
Also to comment it's click on click off. Like a doorbell signal is pushed once to turn on and keep on till doorbell pushed again so goes off. Why I need that 555 circuit to handle it. Although have seen 2 x transistor model todo this I am not fan of transistors as part numbers are not clear enough!
Also the circuit posted with 1 or 3k resistor from 3v supply still did not work! Maybe I got the wrong transistors but how do I know which one to use again damn finding out what transistor is one to use.
Also I get 5v passing through the transistor and when push the doorbell goes to 3v go figure! Maybe just this to expert for me to figure out been over a week now so think have to give up and go turn on my outside lights with a switch and go outside rather than being able todo it with this doorbell signal!
After watching many youtube videos on transistors from what I learned seems they can't do what I want or what was told.
Offline KTP
« Reply #18 on: August 02, 2012, 06:36:43 pm »
transistors can do everything, it just takes more of them than maybe you want to use, so you might be better off looking at a different circuit.
You could build a t-flipflop from transistors for example, then use this as a simple state machine with the output of your 240V relay and the input from your doorbell switch.  It is a lot of parts IIRC.
Offline G7PSK
« Reply #19 on: August 02, 2012, 08:37:19 pm »
Just one self latching relay, forget 555 and transistors just use the 3 volts to work the relay there are relays that latch available of the shelf.
Offline KTP
« Reply #20 on: August 02, 2012, 08:45:14 pm »
I don't think a latching relay by itself will do what the OP wants done.
On the first application of a 3V pulse, he wants the relay to latch.  Ok, easy.
But then the next time a 3V pulse comes, he wants the relay to unlatch.  This is a toggle type flipflop machine...can't be done with one latching relay.
There are some papers on doing this with 2 or 3 relays, some diodes and capacitors...
You can get jk or t flipflops in 74 series dip packages, add a output boost transistor before the 120v relay, and have this circuit done in about 5 minutes.
« Reply #21 on: August 02, 2012, 09:04:15 pm »
Yeah I am surprised this is hard todo. Is it me designing something that cannot be done? I thought electronics was awesome after watching all EEVblog but guess need more tools or components.
If you think what I want done a 555, a relay and 2 transistors plus cap and some resistors you should be able todo this. Can't understand why I can't grrrrrr
Offline TerminalJack505
« Reply #22 on: August 03, 2012, 01:20:14 am »
If you really need a solution that uses the existing 555-based circuit and uses just transistors to replace the switch and hook up to the doorbell's output then here's a solution.
It's basically a discrete tri-state buffer.  The En input would hook up to you 3V doorbell signal.  (Which is assumed to be 0V when off, BTW.)  The D input would come from where the switch's left hand side currently is.  The Q output would go to where the switch's right hand side currently is.  Everything in the dotted box would replace the switch.  Everything outside of the dotted box is for simulation purposes.
Offline IanB
« Reply #23 on: August 03, 2012, 05:29:37 am »
Wayne
Do you need both the doorbell and the 555 on/off circuit, or just the 555 circuit? Because the simplest and most logical solution is to use the doorbell push button as the on/off switch connected to the 555 and to disconnect the rest of the door bell.
Offline PA0PBZ
« Reply #24 on: August 03, 2012, 09:20:34 am »
Let me guess, it's a wireless doorbell  :D
