Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Voltage drop across fuse - what to expect?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Voltage drop across fuse - what to expect? (Read 4032 times)
FlashEF
Contributor
Country:
on:
August 03, 2012, 03:37:28 pm »
I'd like to use a fuse in an circuit powering a mobile robot (MicroMouse) from a LiPol battery. The fuse is going to be a protection device in case of a hard short of power lines, in order not to blow up the battery (which has no protection what so ever - its an RC hobby battery).
Fuse name:
Littelfuse 0154005.DR
Datasheet:
http://www.littelfuse.com/data/en/Data_Sheets/Littelfuse_fuseblocks_154_155.pdf
There is nothing about resistance/voltage drop of this fuse. Is is supposed to be so insignificant? My battery nominally has 7,4V so say half a volt of drop on the fuse would be really much.
Logged
Short Circuit
Frequent Contributor
Country:
Re: Voltage drop across fuse - what to expect?
Reply #1 on:
August 03, 2012, 03:48:56 pm »
Look for the datasheet of the furnised fuse. That contains additional data, including "nominal resistance, cold ohms".
Logged
FlashEF
Contributor
Country:
Reply #2 on:
August 03, 2012, 04:40:57 pm »
Thaks - knowing what to search it was easy to find. It has cold ohms specified in the fuse family data:
http://www.littelfuse.com/products/fuse-blocks-fuseholders-and-fuse-accessories/fuse-blocks/154/0154005_drt.aspx
For this particular one cold ohms are: 0.0136R. So the voltage drop should be really in the millivolt range.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
